only way to find out try another ram, which can be a hassle, not like you got a shop to try another ! been there myself in the past, maybe just try 1 ram installed
Mate is this the ram you got https://www.overclockers.co.uk/showproduct.php?prodid=MY-445-CS&groupid=701&catid=8&subcat=2557
yeah thats what i got
Nice its back in stock, so managed to cancel my 2666 order and getting same as you now 3000, so at least i will know for sure its compatable, did it boot up straight away ok for you ?, just got to hope my motherboard and cpu is ok. cheers
Thx mate, i just hope it was the ram causing my problems, it was the 2 x 8 you got and not 4 x 4 sticks ? cheers
uscool, got your 980ti yet mate, also when fitting your NH-D14, instructions say to tighten the screws until they stop, is that how you installed your fan, cheers
, there are no screws to tighten the fans, its a clipHi, no tomorrow, there are no screws to tighten the fans, its a clip
I mean when you put the spacers and the backplate on, then when you use the 2 spring screws to connect the cooler itself to the mounting bars, instructions say to tighten the screws until they stop.
Do you turn your power off at the back of your case, i have to otherwise all motherboaqrd lights stay on, and keyboard lights, only trouble is, i loose all my bios settings each time i do this ? strange.
dont think it matters, as it controls both same even if they on different headers and you get RPM reading for both fans
