Thats next job. Chainsawing next weekend and refilling the log shed ready for winter![]()
can of petrol and a matchbook is easier
can of petrol and a matchbook is easier![]()
When I DIY, I DIY!
150 tonnes of type 1 stone and a bit vibrating roller!
150 tonnes??There's no way there's that much, how deeply laid is it? That's what 8 tipper lorries at ~20 tonnes each?
Are you laying anything else on top?
They are, they're "SHARKIE" if I remember rightly. She's been looking at them for months and hadnt yet bought them, so took the opportunity so treat her
Guessing just the wife underneath all that!Are you laying anything else on top?
Air Force 1 Quai54 World Streetball Chamionship
Sure he means 15t. 1t is roughly 0.75m3. 15t @ 150mm = 100 sqm
10 metres of flat cat6 so I can used a wired connection through to the spare bedroom.
Did you consider home plugs?
I did, but the flat cable runs flush under the edges of the flooring so it's unobtrusive and ensures there's no wireless issues from my crappy router.
