Hi, having an issue with my Evga Titan SC X, in both the bios and GPU-Z it shows as only running at PCI-E 3.0 x1
It downclocks on desktop and GPU-Z states its running at x1 1.1, when I try the render test or a game it goes to PCI-E 3.0 x1. Tried setting Gen 3 in bios that made no difference.
Spec is;
i7 5280k,
Evga X99 Classified (latest bios),
Evga Titan SC X (tried last two Nvidia drivers),
Samsung 850 pro (with a brand new Windows 8.1 install),
Corsair AX1200i.
I only changed to this setup yesterday, had been running an i7 4770k in an Asus Maximus VI Extreme fine, until last month when I turned PC on and I couldn't get anything on the display. Found the Titan X had stopped working in the top PCI-E slot, moved it down the board and it worked fine but at a maximum of PCI-E 3.0 x4. Thought the board was dying so decided to use it as an excuse to change, but is it my card at fault?
Any ideas?
Spec is;
i7 5280k,
Corsair AX1200i.
Any ideas?
