New Desk..
I hate long desks.
I'm a corner desk chap.
I'd like a corner desk but my room is not very big and most desks I've seen are 140-160 cm whereas I'd like one that's 120 cm or under so it would fit just on the left as you go into my room without impeding the door. Gotta be able to shut the door from prying eyes whem I'm "working from home" :)
I am not a fan of IKEA as most of their stuff is utter garbage but I did but one of their corner desks that you build to spec and it has served me well for 2 years. The only comment I would make is the surface marks very easily and bugger me make sure you get it delivered as it's BIG, so won't fit in anything less than a van. I forget the name, but there was a main corner bit and then an extension.
Just be aware for ikea table tops, they are hollow (cheap). You will hear it when typing.
Better to get a solid peice of wood tbh.
Currently rocking the karlby/alex/signum combo with a monitor stand with 2 arms from amazon.
Looks awesome and is very solid. Would recommend.
