- 30 Nov 2011
Fair conclusion on 4K with a single card, but I wonder why they didn't test any 2 GPU setups
http://www.extremetech.com/gaming/2...y-x-faces-off-with-nvidias-gtx-980-ti-titan-x
While we do see some evidence of a 4GB barrier on AMD cards that the NV hardware does not experience, provoking this problem in current-generation titles required us to use settings that rendered the games unplayable any current GPU. It’s reasonable to ask why we didn’t fine-tune results, attempting to measure the impact of just going over the 4GB threshold with the GTX 980 Ti or Titan X, and then test with those settings. Unfortunately, GPU-Z simply doesn’t measure accurately enough to make this possible.
The most we can say of a specific 4GB issue at 4K is that gamers who want to play at 4K will have to do some fine-tuning to keep frame rates and resolutions balanced, but that’s not unique to any vendor. If you’re a gamer who wants 4K and ultra-high quality visual settings, none of the current GPUs on the market are going to suit you. HBM2 and 14/16nm GPUs may change that, but for now playing in 4K is intrinsically a balancing act. The Fury X may require a bit more fine-tuning than the 980 Ti or Titan X, but that’s not grounds for declaring 4GB an unsuitable amount of VRAM in today’s games.
