Watercooling virgin requires help with build !
18 Jan 2009
Right I plan to get a new x99setup and GFX cards here is my system roughly.
YOUR BASKET
2 x KFA2 GeForce GTX 980Ti "Hall of Fame WC Edition" 6144MB GDDR5 PCI-Express Graphics Card (98IRH5DHH3WT) £719.99 (£1,439.98)
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) £299.99
1 x Asus X99-Pro Intel X99 (Socket 2011) DDR4 ATX Motherboard £259.99
1 x Phanteks Enthoo Primo Full Tower - Black/White £179.99
1 x TeamGroup Vulcan 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - White (TLWED416G3000HC16AQC01) £119.99
1 x Microsoft Windows 10 Pro 64-Bit DVD - OEM (MS-FQC-08929) £116.99
Total : £2,416.92 (includes shipping : Ex.VAT).
I can change the case / motherboard if required going for a white black look.
I have a budget of around £600
Spec me a loop please :) Would like to either have white tubing or white fluid. As this is my first build would be nice if the water was non conductive.
Really want to keep temps down but dont want it to be loud :)
Cheers for any assistance :)
Just noticed I haven't got any way of draining above so would need some help with what to get if the above is ok.
Also my friend who is buying my old PC, so i need to order most of this come Friday any feed back would be welcome before then :).
Stressing abit about it all now :)
Also worrying about the radiator choices fitting ok.
For a drain this is what you need
YOUR BASKET
1 x Aqua Computer Ball Valve Female Thread G 1/4 without Fittings £5.99
1 x XSPC G1/4" 4 Way Fitting (Chrome) £3.95
1 x EK Water Blocks EK-CSQ Plug G1/4 - Black £2.29
2 x XSPC G1/4" 5mm Male to Male Fitting (Black Chrome) £1.79 (£3.58)
Total : £15.80 (includes shipping : Ex.VAT).
Fit it all together into your loop at the lowest possible point.Your also gonna need a SLI terminal bridge for the GPU's,or a couple extra fittings.
The 360mm rad wont fit in the bottom,the bottom rad has to be 125mm wide or less in that case or it wont fit.
YOUR BASKET
Could i put the drain on the bottom rad ?
How do i know what terminal bridge to get ? if i dont what kind of fittings do i need.
Sorry for the silly questions watch quite a few videos but none that focused on SLI. ( or drains )
Nope,its crossflow rad,due to the placement of the bottom rad it would be impossible to hook up fittings to one of the 2 threaded ports.
YOUR BASKET
1 x Coolgate G2 Radiator 10 FPI - 360mm £67.99
Total : £67.99 (includes shipping : Ex.VAT).
^This is a standard version of that rad and should fit fineYou could put your drain port in the fifth 1/4 threaded port on the opposite end from the standard in/out threads :cool:
The terminal you need will depend on your motherboard and the spacing between the PCI-E slots
YOUR BASKET
What bridge would i need according to this picture ?
http://media.webcollage.net/rwvfp/w...a2b2-a9d9-4f07-9aed-b65f93ad71a0.JPG.w960.jpg ops forgot the link.
Highly unlikely an EK part will fit a bitspower block. In which case you need 12 fittings not 10.
