Disney Art Piece Mounted Wonkey
28 Mar 2005
A very vague title i know ;)
I bought a Eric Tan - Starwars: Return of the Jedi Limited to 100 piece for my office.
Its mounted in the frame wrong, and as its now sold out i can't get a replacement. Its quiet a way off as well. Disney are giving me a 20% gift card to spend at the store which is fine....
I want to get it straightened up though, if i take the paper seal of the back to access the frame and adjust it i will damage the value will i not?
Should i just put up with it and leave it :(
[/URL][/IMG]
Take it to a framer and let them have a go? Probably the best bet when it comes to not damaging it.
That would annoy me so much, infact even looking at the picture is getting me all twitchy.
Is it taped down, or is the pressure of the card border and frame back holding it in place. Might move if you give it a whack.
Yeah that's just how they frame it. I would take it to a framer and get it re-done.
They'll attached the Star Wars authentication to the back again like it is there.
Would 100% take it to get re-framed, that's awful. Couldn't cope with it like that.
But it's an awesome poster.
1 question:
this is for now or the future?
if for now, get it sorted, if for the future and future value, get it done properly.
If you want it for future selling then keep it out of the sun and the colours will fade.
pretty simple really.
