** DUAL GPU GREATNESS & 16GB RAM!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK Powercolor have used their expertise with dual GPU cards and created a 390 X2 monster with a pair of 390 cores, incredible power design and 8GB per GPU for a total of 16GB of memory.
Certainly a great card for 4k and I believe the most powerful single card on the market now, this really is a Devil !!!
Powercolor Devil 13 Radeon R9 390 X2 16384MB GDDR5 PCI-Express Graphics Card (AXR9 390 II 16GBD5) @ £689.99 inc VAT
PowerColor Devil 13 Dual Core R9 390 is built with carefully-designed Platinum Power Kit and ultra-efficient thermal design. It consists of massive 15-phase power delivery, PowerIRstage, Super Cap and Ferrite Core Choke that provides the stability and reliability for such high-end graphics solution. To support maximum performance and to qualify for the Devil 13 cooling system, 3 Double Blades Fans are attached on top of the enormous surface of aluminum fins heatsink connected with total of 10 pieces of heat pipes and 2 pieces of large die-cast panels. This superb cooling solution achieves a perfect balance between thermal solution and noise reduction. The PowerColor Devil 13 Dual Core R9 390 has the LED backlighting that glows a bright red color, pulsating slowly on the Devil 13 logo.
The Dual BIOS button design allows gamers to pursuit extreme performance in the easiest way to control. Four units of 8 pin PCI-E power connector draws more power offering constant and stable power input. What's more, to honor Devil 13 users, we have included the top-notch gaming mouse, the Razer Ouroboros, as a free gift inside the box. Why? Simply because we strongly believe our Devil 13 users deserves to have the best of the best.
The PowerColor Devil 13 Dual Core R9 390 graphics card supports for AMD LiquidVR™, GCN Architecture, Mantle, Exploit DirectX© 12, AMD CorssFire™, Virtual Super Resolution, HD3D technology, Frame Rate Target Control, and AMD FreeSync™ technologies. Once more, the Devil 13 has risen from Hell and will once again dominate the extreme gaming world with ease.
Specification:-
- GPU: Grenada Pro x2
- Stream Processors: 5120
- Core Speed: 1000MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 16384MB GDDR5
- PCI-Express X16 lane required
- 1000W Gold or greater PSU required
- Power Connectors: 4x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Includes Razer Ouroboros Gaming Mouse
- Warranty: 2yr
Only £689.99 inc VAT.
ORDER NOW
Awesome looking beast :D how does this compare to the 2x295? I'm guessing faster, less energy hungry and with double the VRAM?
Also does anyone think it's odd they bundle a £100 mouse with it when they could have supplied the required 1Kw PSU instead? lol
I think raw performance in benchmarks will be very similar to the 295 X2, butt this will be better for gaming due to double the VRAM per GPU. :)
Holy Mother of Satan!! 16GB VRAM!!! :eek: I currently have a 295x2 myself, but one day, when and if these go down in price, I just might get one. Imagine crossfiring two of these doe!! 32GB VRAM!!
Doing a bit of a DFS advert on you, making it sound better than what it is. It'll still be 8 gig of vRAM. 8 per gpu die. Xfiring will still give you 8 per gpu die.
To clarify,
Is this 16GB split? I.e. 8GB per GPU?
Is it DX12 ready?
Don't think I'll be moving from my TX.
8GB per card, DX12 ready. It's tempting but my Titan is underwater now so won't be changing for a while I don't think. Next change for me will be when a significant number of games are DX12 and SLI/CF is running a lot more smooth. I don't think I've ever spoken to anyone who hasn't had issues with CF/SLI.
Also the power draw for this dual GPU is 675W minimum I think.
This better than the 980TI HOF 8 pack edition ?
Wondering should I swap my 980TI for this on my new build !!
Well, doesnt this card consist of 2x "290"(@390) while 295X2 consists of 2x 290X..?
The X is missing, and if so, then stream processors and texture units as well..
So how ur statement can be true ? :)
