Thanks to Shamrock also for pointing out the Royles 50% off all shoes sale. I now have a nice pair of SPD-SL shoes (Fizik R5) at the bargain price of £65.
overpriced.. just get a kilo/two of myprotein/tpw or bulk powders protein and it'll be very similar!if you want protein shakes..
I'm confused, FT is the only person I'm following that's ridden that segment... Am I missing something, it's quite early, caffeine hasn't quite kicked in!
Good to see im the fastest of janp's friends up Great Dunn Fell, I need to go up again, I stopped to take photos half way up.
I think he was getting mixed up with Roady![]()
is it wrong that I want to ditch my carbon/sram rival bike and get a similar spec bike with disks?
No it hasn't, the smallest diameter is at the 11 o'clock position rising up to the largest after it passes 1 o'clock. And it's not a big difference, it's about a 5mm change in diameter. I checked mine this morning.biopace and q-rings are quite literally opposite. biopace have the largest diameter at the deadspot (12 and 6 o'clock), q-rings have the smallest diameter at the deadspot. The two can't really be compared (as far as I've read).
That said, I'll def be getting a bike fit once I've got my new bike![]()
No. It's the most right you can ever be![]()
Alright, I have a really, really dumb question. I've got Tektro R540s on my bike and from what I understand they have Shimano compatible cartridge style pads. I've removed the grub screws holding the pads in but I can't get them to slide out. They just won't budge, not even a little bit. Should they slide out easily or am I missing a trick somewhere?
I really don't want to have to go to my LBS to change some brake pads!
buuuut, I'm getting a car soon too so I need to buy that first before I go for a special bike![]()
EDIT: May be a really really stupid question - but it's definitely cartridge style brakes? The Tektro ones on my Giant Defy weren't originally - they were just pads that attach directly to the caliper. I replaced them myself with the catridge/pad ones once that first set of pads died.
Ditch? No N+1? Should be easy for you as you've never mentioned a mrs^grudas![]()
Why car after you've managed a while without one? They're expensive in london... And I'm not talking about just the purchase of one...!
basically.. my idea is that I can totes commute on my SS during winter, I like the ride, it's smooth, I can top out at 34ish mph which is more than enough etc.. so I want something super special, something in 2.5-3k range I guess![]()
Cheers for the tips guys. I'm definitely pulling them the right way and they are *deffo* cartridge ones. Will try being a little bit more 'persuasive' with them tonight...
