Condensation
6 Jan 2013
Rollergirl
If the liquid in the loop is always equal to, or warmer than the surrounding air temperature, is there zero risk of condensation no matter what the delta?
That is correct yes, you can run your liquid a few degrees cooler and still get no condensation but factors of humidity come into play here.
You're planning on putting radiators somewhere cold, right? Like outside or garage?
In normal running you won't have a problem, but what you will need to be careful of is on startup, where your indoors air temp is 20C but your startup fluid temp is around that 4C
Or what?
Otherwise if fluid temp is always higher than the air temp of ALL the components then you can't get condensation
Condensation forms when warm wet air hits a cold surface, if the fluid is warm then all the components will be warm so there's no cold surface to condense on
Or what?
Nearly. The whole setup will be in my garage. That's why the liquid in the loop will usually not be colder than air temp.
The only curve ball would be if temps were to plummet overnight and then rise quite quickly in the morning, where the liquid might stay cooler. Although I'm not sure this will be a factor.
I assume ya only staying in the garage over summer? Might not be great having a water cooled PC in a garage overnight if its freezing outside.
As for condensation, your garage should stay nice and cool as theyre normally well shaded and a good place for storing beer, providing you dont keep your tumble dryer in there :)
Ever thought of using a pond pump(£20) and a bucket full of ice, salt and enough water to cover pump?? You could get subzero temps and your cpu/VGA will love you for it!! Just wrap kitchen roll around blocks and pipes and your good to go! You should gain 200hz+ on cpu and around 150hz+ on vga, i've a thread at MLG regarding this.
I ran my aircon through one of my rads one summer for a laugh, got very low temps, but also got a tonne of condensation, just managed to power down before it all started dripping onto my mobo.
It would have been fine if i had kept my GPUs under load but i must have alt tabbed out to check a forum or summat and forgotten i was chilling the water. :)
Ooh, forgot about tumble dryer! Will keep an eye on that.
Sounds interesting, will have a look. :cool:
