I think you are looking at around £200 for genuine Cam and Aux belt kits, about £150 for the dephaser and I'm not sure on the waterpump, say £40 and then another £10 for coolant. So that is £400 on parts. You then have labour charges on top of that.
Isn't cambelt service at 60k on these?. I supose if you have the money no harm in getting it done early.
£60 for MoT?, i dont think i've ever paid over £30.
If the rear shocks are fine then they dont need doing.
At the end of it you will have a great little hot hatch mind.
Diamond motors in Notts for the cambelt/service. The damper refurb could well be a lot more depending on their condition.
Would probably be about £5.5-£6k in good condition with belts and dampers done.
Should be done every 33k~.
How much is he selling the car for?
100% keep the Sachs, the only reason people don't put them on and use aftermarkets is because they can't afford them. Prices do vary insanely. I sold my 182FF for £1000, but for various reasons other than it's worth.
Easy cars to work on to, or at least I found them easy to. Just keep a big hammer close by!
You'll want to get the water pump changed, along with the dephaser when doing the belt. IIRC it cost me about £340ish when I got mine done at a Renault specialist. Not worth doing on your own, the part to do the timing is close to £300 and from what I hear it's a total crap job.
http://www.roadtrackraceparts.com is the goto for brakes on a Clio Sport.
"Refurbish the sachs dampers. He doesn't think they need doing yet but recommends it. ~£400?"
what ever you do, dont refurb them, if there is nothing wrong, some refurbs can last 30k miles before they fail
£400 if nothing wrong when they strip them down, other wise it could be as much as £1200+
BG motorsports seem to offer the best service atm, they offer upgrades which should increase their life span, i would also get the belts done, if not recently changed
have you checked it still has SACH on the rear?
Front dampers from Renault are around £1000 each!
i have never heard of doing the belts at 3 years either, it should approaching its 2nd change, unless its done insane mileage
once you have given it some love, should worth £5k
might be worth signing up to cliotrophy.co.uk they have a sticky thread on the front and rear dampers
To the Op, if you are being offered the Trophy for somewhere around £3000 - £3750 given the work it needs its probably a pretty good deal. If you are being asked much more than that it's probably not much of a deal and you'd be as well buying a sorted one in the first place. There was recently a poorish condition Trophy for sale near me on Autotrader for £3750.
As mentioned check when the belts were last done. Aux belt is every 36k or 3 years (whichever is sooner), cambelt is every 72k or every 5 years (whichever is sooner). Always get the aux belt done with cambelt. Don't let anyone else do it but a specialist - Diamond Motors is your closest place in Nottingham and Mick is a good lad.
Waterpump and dephaser aren't always necessary, dephaser only needs doing if sounds like it's whining.
Get the dampers refurbed properly, it's what makes the car and buying second hand you won't know what condition they'll be in. You wouldn't buy them new because they're over a grand at least for a pair.
Pilot sport 3's I think you're correct on price, MOT you're being conned though.
Brakes are doable by yourself as is oil change, check what spark plugs he changed them with - if they're Bosch then you'll need to take them out and put in the correct NGK ones, otherwise it won't rev properly.
ClioSport.net is a wealth of info as is the dedicated thread on here. Great little motors and the Trophy is the one to own if looked after and you get a good price.
