Noctua NH D15 Gigabyte x99ud4
21 Jul 2007
Newcastle upon tyne
Hi all,
Does anybody have experience with the noctua NH d15 and gigabyte x99 ud4? I just want to know it the cooler will interfere with the top PCI x26 slot?
PCI x16
Or even any gigabyte board. If it does, does having to move the gpu into a different PCI slot do anything to performance.
According to the Noctua website there will be a clearance issue with NH D15 and a UD4:
"The cooler is extending over the first PCI-E x16 slot, so please use the other available PCI-E slot(s) for your video card(s)."
I've got a NH D15-S in my X99 Gaming 5P (E-ATX version of the Gaming 5 and a very similar layout to the UD4/UD4P and there's a good 7-8mm clearance between the bottom of the cooler in its standard orientation and the top of my GPU (which doesn't have a backplate).
There's an e-mail address on the Noctua compatibility page I linked above to query this. The NH D15S is rated for full compatibility with the UD4.
You have approx. 73mm from center of CPU to near side of PCIe socket, so you need a cooler no wider than 140mm or with an offset base like the Thermalright Silver Arrow IB-E, TRUE Spirit 140 rev.A, Archon IB-E, NH-D15S. Even then if GPU has much on back side of PCB it might not clear.
Will putting the gpu in another pci slot affect performance?
Will you be running a 5820K or 5830K or above? As per the specs page for your board the second PCI-E slot will run at PCI-E 3.0 x8 speeds if you have a 5820K (28 lanes rather than 40 on the 5830K and 5960) installed. It should run at 16x if you have 5830K or above.
1.2 x PCI Express x16 slots, running at x16 (PCIE_1, PCIE_2)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIE_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIE_1 and PCIE_2 slots.
2.2 x PCI Express x16 slots, running at x8 (PCIE_3, PCIE_4)
* The PCIE_4 slot shares bandwidth with the PCIE_1 slot. When the PCIE_4 slot is populated, the PCIE_1 slot will operate at up to x8 mode.
* When an i7-5820K CPU is installed, the PCIE_2 slot operates at up to x8 mode and the PCIE_3 operates at up to x4 mode.
(All PCI Express x16 slots conform to PCI Express 3.0 standard.)
I initially had a NH-D15 for my new Asus X99-S system. It was down as compatible, but was stupidly close to the GPU PCB, so I swapped for a D15S. Much better option, and no change in temps.
I dont have the mother board yey I am trying to make sure all is well at the moment. More so a 5820k
Aah righto. As Credo mentioned I think the best course of action is to opt for NH-D15S (which will definitely not result in any clearance issues) instead. If you have (or have bought) a normal D15 then either try and return it or sell it.
Technically, I believe that you should be able to run a single GPU from PCI_2 of the UD4, but you will be limited x8 speeds with a 5820K. The safer course is to go for a cooler with wider compatibility (like the NH-D15S). :)
The D15S has the same dimensions I believe, but the asymmetrical layout results in the fin stack being off-set (check the 360 degree views on the Noctua website). I can only mount mine "upside down" in the standard orientation because of the fin stack. If I flipped it over 180 degrees it wouldn't fit.
You can add another fan to the NH15S if needed.
Cool thank guys I understand now. Better to go for the NH D15s and add a extra fan if needed. I doubt another fan will be needed if you didn't see much difference in temps. Now it's time to decide on a case. phanteks enthoo luxe, fractal design define xl r2 or define s.
Too many choices!
Its close on my Asus x99-A too, but its no problem at all.
