mobi info on the Gigabyte X99-Gaming 5P Intel X99
26 Jan 2010
Guys im a click away from ordering my new build, just want to double check with the mobo: Gigabyte X99-Gaming 5P Intel X99
I hear that you can buy an optional next gen wireless ac network card, it does not come with the board, you have to buy it seperatley, but Ive looked all over the net and cant see anything in relation to the wifi card, i would like this optional wifi card as it will free up a pcie slot, any one know?
https://www.overclockers.co.uk/showproduct.php?prodid=MB-515-GI&groupid=701&catid=5&subcat=2875
Also this mobo is £30 more dear than the GIGABYTE X99 ud4P, which one is better?
https://www.overclockers.co.uk/showproduct.php?prodid=MB-513-GI&groupid=701&catid=5&subcat=2875
Also the Asus X99-Pro Intel X99 is £259 which x99 do you think i should go for?
https://www.overclockers.co.uk/showproduct.php?prodid=MB-632-AS&groupid=701&catid=5&subcat=2875
on standby
The 5p has creative sound chip and the upgradable op-amp plus fancy capacitors for the audio, it also has KillerNIC.
I have not seen that wifi+BT card sold separatly, only PCI-E add-in ones.
hmmm isaw it on a you tube review,also there are 2 holes for the antnennas on the mobo.... no ingo on google what so eva
i have a sound blaster zx so the sound chip wont be used, but what is that killernic? i use wifi for online gaming, thats a wired lan thing right?
Guys the Gigabyte X99-Gaming 5P Intel X99 vs the Asus X99-Pro Intel X99
i see the asus has 4 x PCI Express 3.0 slots
does the gigabyte X99-Gaming 5P have pcie 3.0? its not on the product listing..
if you were buying what would you choose out of the 2,, and why?
sorry i just need to be sure im getting the right mobo as im not to savvy on the tech specs of mobos
