sticker residue removal
7 Jan 2009
Any personal suggestions that you have tried and it worked well?
Heard WD40 does the job,But i have none lol,And its for a bike that the stickers/decal come off..have to be a bit carefull what i use though as the bikes white don't want it turning the paint yellow.
White spirits works well. Often use it on new timber at work to remove tape glue residue.
Tar and Glue remover.
AG stuff sold by Halfords is okay but it's not the best compared to some stuff you can get.
Yeah IPA and some patience will be fine. You might need to soak the label so apply it to a sponge or paper towel and hold it on the label for a while.
