Help me change car
Corsa is a bit of side step from a Clio Sport though. Probably more power, but less handling characteristics. Can see it being just as much fun as the Clio. The Clio will do 38mpg~ at 70mph on the motorway too.
What about saving a bit more and a decent Octavia VRs?
6k is more than enough to get a decent VRS, petrol or diesel, maybe not one less than 5 years old though,.
Diesel is 0-60 in 8.0 and 47mpg combined, Petrol is 0-60 in 7.0 and 37mpg combined
The ride isnt great but replacing the shocks with Bilstein ones improves it no end. A couple of nice ones on Briskoda at the moment
http://www.briskoda.net/forums/topic/370210-octavia-vrs-20-tfsi-2007-57-62k-stunning-car/
http://www.briskoda.net/forums/topic/364177-2008-octavia-vrs-tfsi/
http://www.briskoda.net/forums/topic/365304-2007-škoda-octavia-vrs-tdi-pd-170-£4950/
Thank you.
This is the sort of post i was after!
Im not a fan of the saloon shape, but im sure it could grow on me, those cars sounds lik a lot of car for the money.
I am just putting this out there:
£5,500 MAZDA6 2.2 D Takuya 5dr
Personally I wouldn't buy a diesel again, but it's 0-60 time is 9.2 which is almost what you want, good fuel economy. Nicely specced car. Not sure how good the diesel engine is on this though, might be awful haven't looked into it.
They're nice engines to drive, but have plenty issues with the usual stuff like DPFs
I know high mileage isn't necessarily a problem, but not sure I would want to spend 5.5k on something with 124k miles
You will be disappointed if you're expecting decent mileage out of a Leon FR. The TSIs drink fuel like crazy if you go anywhere near the throttle.
I love the look of that car. If only it was under 100k miles. I would sacrifice the performance
Real world tests show the Alfa doing 47Mpg and the Leon doing 43mpg. Both cars fall within my range. So its possible to find the car i want...
Not saying it's not possible, just wonder whether it's worth the hassle for a potentially small saving as compared to 55-60mpg options. Just things to consider ahead of picking your final choice.
Unless your doing LOADS of miles I'd go with petrol TBH.
These days you can have a nice and light, 1.6t petrol that will run rings around a diesel and get 40+ MPG. Plus much cheaper to maintain.
But your unlikely to find the specs you want for £6k (and still in good condition).
Nice edit - but correct, as other than 1.6T corsas, you will struggle to get a decently fuel efficient petrol engine car in that price range (small turbo petrols are still a relatively new thing - e.g. last 3 years and so still command a premium)
Not sure where the cheaper to maintain bit comes in really, as other than a DPF there is nothing different to maintain (i.e. at lot of modern petrols now have a DMF which was a common stated diesel related issue)
14k/year mileage arguably either petrol or diesel are both viable choices - wouldn't have thought there would be much in it.
Sounds like I'm stuck tbh
The difference is the rate at which diesels go through DMFs due to the torque and more rattly nature of them
