** DDR3 PRICES HIT BOTTOM LAST WEEK, PRICING NOW IN UPTREND, UPGRADE NOW!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
DDR3 prices bottomed a couple of weeks ago, the trend since has being uptrend and seems to continue.
The two below deals are actually being sold at below our re-buy cost making them a great deal:
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) @ £32.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-12800 1600MHz CAS 9-9-9-27
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Was [£38.99] Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP8G3D1609DS1S00CEU) @ £59.99 inc VAT
- 1.5v VDIMM
Was [£68.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) @ £32.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
Was [£35.99] Inc. VAT
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £59.99 inc VAT
nonl2br
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.<br /><br />
Features:-<br />
- Module Type 240Pin L-DIMM 1600 <br />
- CL-tRCD-tRP-tRAS 11-11-11-28 <br />
- DRAM Density 256x8 / 512x8 <br />
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800) <br />
- Heat Sink Aluminum heat-sink <br />
- Working voltage 1.5V± 0.075V <br />
- Warranty Lifetime warranty <br />
Was [£65.99] Inc. VAT
ORDER NOW
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) @ £38.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£49.99] Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £68.99 inc VAT
Features:-
Specification:-
Was [£89.99] Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
DDR4 is now the focus moving forward so it is now unknown if DDR3 will come back down or now remain in uptrend as manufacturers shift more focus onto DDR4 with Skylake taking over quickly with SI's.
DDR4 Skylake notebooks will also be coming October onwards as well, so the shift to DDR4 is happening and very quickly. :)
They're great deals, but it's still a bitter pill to swallow at 150% of 2012 prices (I know it's the manufacturers gauging the prices not OCUK).
I am just about to finally upgrade to Haswell, I have 8GB of RAM at the moment and am contemplating moving up to 16GB. I really don't know anything about what makes RAM 'good' though, can point me to some decent guides that explain timings or CL numbers? I was just going to pick 'fast' DDR3 RAM...
Got 8GB at the moment and can't see any point in upgrading to a 16GB DDR3 kit now. My next upgrade will undoubtedly be DDR4 anyway whenever that may be.
Same here,I have 4x 2GB sticks of G.Skill Ripjaws 1600Mhz (7-8-7-24) timings,Dont see the point in upgrading to faster ram as my rams timings are good.
Thanks for the heads up Gibbo. Just saw my current memory (Patriot Viper 3 black mamba 2400mhz) is silly low price now. I wanted to get a second ssd or AIO cooler, but would seem silly to not get another 8gb now.
