I am only having a rant - not happy? I dont care, dont read it. I only dotn this for myself really
I started to get heavily into Water cooling way back when the P4 was the main heater in the home, and I was really clocking the naughty bits off the old setups, but I think that the Q6600 was the last CPU that I bothered to clock, and to be completely honest, CPUs are so fast, and have been for some time, that I feel that clocking is just mostly unecessary, so I have simply stopped doing it.
I am kind of gutted that I have got rid of my old bits now.
Recently, I have got into the simpler basic enclosed CPU only setups as they offer a nice little compromise of having good cooling + water + simplicity and of course much less chance of me messing it up and leaking the bloody water everywhere and killing my brand new 8800 even though I couldsmell somethign for hours before it did go pop ( ahem )
But anyway, I have bought a few of the enclosed setups, a couple of Corsairs, and a nice Alpenholm or whatever the hell it is, plus even a cheap and nasty cool-it that for just £25 was ever ybit as good as the Corsair H80 which was a big surprise, but anyway, I have been toying with the AMD 9590 today... a CPU taht quite frankly should be banned as being the most horrible thing to buy since the Celeron.
Now, the Alphenholm is what is in the 8350 system, and its keeping that at a fairly comfy 33c under load 24/7 and so thats great. I plopped in the 9590 and I dont even get to the desktop before it shuts down? After much checking, I burn my fingers on the Radiator, and the dangerously soft pipes are not filling me with confidence either, so, after letting them cool down, I power on and get right into the BIOS and go straight to the temp monitors only to see it go 63, 64 up to 70c and then it goes off... Seemingly at the 71c mark.
I make doubly sure the CPU is seated right and the block is sat comfy and the TIM is plastered nicely etc and I just cannot stop it from practically putting a gun to its head every time I try to start it.
So, I decided to try a small experiment...
I have a few Radiators upstairs, a double, and a 2x2 Quad Radiator that is for the TT Mozart TX too ,and so while using them, might push the pump a tad, I need to try something just for now, to get that sodding CPU to at least run enough for me to get to the desktop and have a play for a bit.
I decide to sacrifice the CoolIT... ( ARGH! - I should have checked the size of the pipes first before introducing the Stanley knife ) but not worries, thats why they invented punture repair kits and glue LOL.
So, anyway, after much acting like I know what I am doing, and filling the huge 4x120mm radiator with water an Ford Focus pink coolant ( all I got so leave me alone - and its probably placebo anyway ) and also the pump block and its pipes too, I manage to wedge the pipes onto the rad, and with very minimal air too, and I use the puncture repair kit to strengthen the seal with more rubber before using a couple of cable ties to pinch it closed each end, I think its ok...
I start it up out of a case and it pumps just fine for a good few minutes, so I chuck it into a PC case, only to realise that the radiator needs to go OUTSIDE the case... Stuff it, its too late for details now, so I just sellotape it so it does not go anywhere ( bobs got nothing on me ) and I start her up and shoot straight into the BIOS again and this time I see 52c as the first temp rather than 63 so it seems to be definitely a bit better, but then the temps creep up still... It does however float at 66/67c
I resetart it and let windows come on, and it gets there, and speedfan is now showing 70 and then 69, so its borderline.
I run Dawn of War to try to play the game asnd it powers itself off!
Anyway, it was only a small experiment and it did the job, and its clear that I have 2 choices for this setup.
Splash out on a whole decent and proper Water cooling setup, or get rid of the 9590 and stick with the 8350?
Its a simple choice really... After all... This is NO longer my main PC, I would be much better off leaving it as is and gettign my money back for the 9590 instead.
So thats what I have done.
I am sure that I still have a pump or two and I am also sure I have a resevoir, but IIRC they are odd sizes...10 and 12mil I think, so I might knock up a W/C system with what I have left, but Im not wasting money on it.
I have spent just over 2 grand this last month on PC bits and if the wife only knew just how much, I would be killed and buried under the patio - brookside style.
