- 15 Dec 2009
Have I got a defective Samsung U28E850R? ##Solved##
Hi all,
Been having some issues with my U28E850R. I'm trying to run it on 2x Sapphire R290 Vapors in crossfire but I am getting some major freeze frame and the Freesync mode does nothing.
The only way I can get it to work without any skipping is by connecting it with the DVI/HDMI connection, but the Freesync doesn't work with this cable connection and the whole reason I got this monitor was to use Freesync. And I get the frame freezing issue with both the HDMI-to-HDMI and the Mini DP-to-DP connections.
AMD site confirms my cards support Freesync monitors witht he latest drivers. And I downloaded the drivers for the screen from Samsungs site too.
I've only tested it with GTAV, and plan to do some trial and error at the weekend - ie. try it on each card alone and also on another PC with Win 7 on and i'll stick the 290's in there (currently running it on Win 10 with latest drivers* - not the Beta that got released last week though).
Has anyone had any issues with these screens or can anyone recommend anything else I could try with getting it to work?
My rig is:
Intel Core i7-4790K 4.00GHz
Corsair Hydro H110
Gigabyte Z97X-SOC Force
TeamGroup Vulcan ORANGE 16GB (4x4GB) DDR3
2x Sapphire Radeon R9 290 Vapor-X 4096MB GDDR5
Samsung 500GB SSD
SuperFlower Leadex Platinum 1200W
Windows 10 64 bit
Thanks in advance.
Hi all,
My rig is:
Corsair Hydro H110
Samsung 500GB SSD
Windows 10 64 bit
Thanks in advance.
