It's very playable, but not the greatest. If I want it faster I usually drop down to High settings.
FYI it is a windforce 3 GFX card so is OC'ed and I am still running an i5 3570K on a Z77 mobo.
This is probably your best bet. There is to many unanswered questions to spend £550 on a card that might not fair well going forward. To save even more dropping to a 390 and doing a spot off overclocking should see you good for a while.
Concerned as i dont want to waste money as i will be getting a new screen to.
< £400 for a 1440 monitor
Worried about Gsync being obsolete in 2years
maybe even less depends how quickly the industry follows amd and intel into Freesync
So yes i am worried about wasting £900
especially as this will all be going to a new build
I get that, but....
Gsync is going nowhere, unless Nvidia come out and say they are supporting their own version of Adaptive sync (which i cant see happening) I'm sure it will stay around for a while. It's also the best option.
Buy yourself a 980Ti and a nice Gsync monitor and enjoy gaming, dont worry what 'might be'.
Oh god someone asked what to buy and they have money. INCOMING NVIDIA SHILLS.
PS. to OP. If you really want to know what to buy, go and look over reviews yourself, don't trust random biased people on forums, look at the numbers and then decide what YOU want, not what someone else wants you to buy
However here is my personal recommendation in order from least to most demanding.
1080p: 970/390
1440p: 390/Fury
21:9 1440: 390/Fury/980Ti
Multimonitor: (3 1080p/1200p) 2x 390/1xFury/980Ti
4K: 2x390/Fury/980Ti
Having owned and used most of the cards on your list, I agree with some but disagree with others on your list and you tell him to ignore randoms but then recommend![]()
The 980Ti (which is pretty much in-line with my TX) will be great for 1440P and the Fury X or 390 just won't cut it if (and a big if) the OP wants to have decent settings. I can comfortably run with max settings on my Titan X (which is in-line with a 980Ti) but couldn't do the same on my Fury X. The 980Ti is cheaper than a Fury X and gives far better performance at the res the OP wants to game at.
Your own links show the 980ti as 20-25% faster than a FuryX, so why would you recommend one over the other at the same price?
No one here is recommending he get a reference 980ti, so if that was the comparison you were making then why bother?
Your first witcher 3 link, 72 vs 59. 22%
And so on... Looking at real 980ti's and not the reference one that no one buys in your other cherry picked links
Even Ashes of the Singularity, being held up as a key example of AMD's DX12 performance bonus, and what the OP mentions as a concern, the nvidia cards are 25% ahead of the overclocked FuryX's
The fury X won't cut it at 1440P But the 980Ti is great for it? That doesn't sound right to me at all.
