New PC received, quick Q on installation plz
26 Jan 2010
Guys just received the parts for my new build
S I have 500GB SSD and a 4TB Hybrid Drive
Can you advise me on where to install windows operating system, on the SSD or the hybrid drive?
I mean the hybrid drive is faster than normal drives but will it be like the SSD?
Im gonna install Windows 7 1st then service pack 1 then on to windows 10 upgrade..
I don't think i can jump onto windows 10 immediately coz the key i have is for 7
ssd definitely, which hybrid drive did you buy?
i got the 4tb seagate SSHD 5900rpm for 140 quid, isn't hybrids suppose to be faster than standard drives?
https://www.overclockers.co.uk/showproduct.php?prodid=HD-296-SE&groupid=701&catid=14&subcat=1894
and for the SSD i got the kingston 480gb ssd
https://www.overclockers.co.uk/showproduct.php?prodid=HD-082-KS
soon im gonna get a crucial blazing fast m.2 500gb SSD stick, maybe i should have added the £50 and got it now instead of the kingston standard ssd !!!!!
anyways im gonna build it right now, 2800 i spent in total, should take me 2 days or so?
Also will be posting from my laptop as im expecting problems, Im just hoping non of the stuff I got is DOA !!!
Make sure you take your time if its your first build. If you feel your getting tired or stressed, STOP, as you might make mistakes.
Another point is, install your operating system with only the SSD installed. Then install the 2nd drive. Windows has an annoying thing where it will put crap on the other drive while its installing and this will slow down your SSD loading times a lot.
oh cheers
i will
well its my 2nd build, last one was the x58 platform 4-5 years ago, again i spent like 2500, so im gonn start now, just having a look on google re some research, i will take it very slow ....
so guys, just a quick re-cap.....
mobo 1st, install the cpu
insert the back plate for the all in one cpu cooler
insert the mobo on the case
insert the ram ssd
then go on from there?
is that a good way to go?
Upload your pics to Photobucket.
Click on picture in Photobucket
Select the Forum link
When on this forum choose 'Insert image' and paste your link in there and after you post reply the pic should show! Trial and error!
thank you, obsticle hit already, cant find the instruction manaual for my cooler master case, need to know what wires are what, i.e power switch, front usb ect, looking on the net now
thanks
edit
I thought that was the instruction for how to insert pics on this thread, but will still help me lolz
er,
mate that instruction does not tell me to add cpu thermal paste, neither does the manual for the mobo, I already bought thermal past, shall I skip it or apply the thermal paste??
