Maybe it's me, but I don't find noctua fans impressive at all. Once they are run slow enough that they are virtually silent, they have little in the way of flow. The industrial PPC versions are much better than the others but not really worth the extra expense. The old Gentle Typhoon is significantly better, producing a lot more flow at similar noise levels. I've never found another fan quite as good, as they are remarkably well balanced with no rotor wobble at all. There is so little resistance in the bearings that they keep spinning for around 30 seconds after switch off which i've never seen any other fan manage. Best of all is that they are now available again in all black via dazmode darkside. (in the uk from mayhems) There is supposed to be a pwm version in the works too.
