Just finishing of my system build but come across a obsticle
On the mobo manual it states that there is a ATX4P header, this is used to help power the PCIe lanes if you are using 2 or more cards...
Currently im gonna use one card, after 2 days of benchmarking and stability checking I will add the 2nd card in to do a SLI set up, just want to see the difference from 1 to 2 cards
Firstly Do I really need to use this ATX4P for SLI ??
also looking at the header its completley covered in black, not sure if there is a cover, but when i try to move it its stuck firmly in, dont really want to use to much force incase I break it,...
Anyone can shed light on this, and how the connection looks like, ie what cable do i need?
