The G1 has a dual BIOS. Read the PDF carefully that comes with it.
The F3 BIOS was set for 300w. F4 is setup for 280w. It runs a little cooler, fans don't spin so fast and the boost is a little lower. I prefer the F4 and which can still boost over 1560. The F3 finished one bench with a max of 1602.
Oh ..... Make sure you backup both BIOS and name them F3 before flashing the F4s. I used the utility that comes with the BIOS.
There is a Gigabyte rep here from time to time. Perhaps he can confirm if you can use a Displayport to update. I would wait for confirmation before trying since you don't have DVI inputs to fallback on.
It does explain the diffitence between the two BIOS files in the PDF.
When I flashed my 970 you use the BIOS corresponding to the input you have the monitor plugged in to.
So I assume dp is display port and dd is dvi-d port.
One thing I had to do in my 970 is actually disable the device in device manager before it would flash successfully. Otherwise all I got was l funky colours on screen.
Don't quote me on that, but that's my two cents.
Im still confused as it seems you have to connect to dvi 1st bios and dvi-d for second bios? Is that right LOL if thats the case its more hassle than its worth I might just buy the EVGA hybrid![]()
They are the same bios. If your connected via DP us the DP bios.
But consult the PDF in the archive. It will tell you.
