**Official Unigine Valley Leaderboard**
Cheers ^_^
I am curious; was 8 Pack's 980Ti on phase change cooling or something? Or just the best chip KFA had? It feels impossible to beat for a regular person.
Edit: Saw his CPU was at 5.9GHz and RAM at 4.8GHz... Definitely not achievable :p
I had my 5820k @ 4.5GHz (x36 125MHz) - I'm not sure why Valley reads it as 4125MHz (x33)? Maybe because it's the regular ratio of a 5820k?
Cheers ^_^
8Pack does have an unfair advantage, not because he's a benching legend but 'i suspect' vendors send him the best clockers.
Maybe there should be an 8Pack board, he can compete with himself as no one else can :p
Hi Joe - excellent scores :)
what CPU@? please.
@Humbug you have Kaap at 36(single card) - should be lower.
fixed, thanks :)
This is what I do in the Firestrike Bench threads, I have a separate table for LN2/extreme cooling.
8 Pack has the highest 1080p 4 way score on this bench using a pair of 295X2 cards but if he tried running the same setup @2160p he would not stand a chance against my 4 TitanXs as he would not be able to use his very high CPU clockspeed to his advantage.
For 1080p an ultra fast CPU is a huge advantage.
Did he use extreme cooling on that tho?
I should have asked.
http://forums.overclockers.co.uk/showpost.php?p=26288665&postcount=1984
Looks pretty extreme to me.
There's nobody else who uses extreme cooling so there's no need to exclude poor Ian.
I don't exclude him in the bench threads I run but I do put all his results in a separate table for LN2.
This is so anyone running a single or 2 way GPU setup can get a more realistic picture of what they can expect with normal cooling. Having LN2 results mixed in with normal cooling just confuses people if they are new to the forums.:)
Your right, i'll make a septate table for it and put him in it.
Fair enough - By excluding I meant excluding from the "normal people" list, rather than excluding his results.
People need to see his results but they also need to know what they are looking at.
As I said above I often put his scores in an extreme cooling table but I also have it as the first table on the scoreboard so people can not miss it.:)
I agree, better if he has his own section, it's great that he takes part etc, but he does have access to cherry-picked parts unlike the rest of us mere mortals.
Some of his scores are bonkers though lol.
Managed to beat my own score by 2, I guess I can update my score by that?
1080p - Score 5020 - 980Ti @ 1560/2120 with 353.49 drivers
I might try for higher some day but trying 2150 memory caused system lockups :l
Edit: You also forgot to remove my previous result (#22) from the 1080p leaderboard :)
My GTX 980s have Samsung memory and can go very high indeed but 2150 is just not worth it as I lose so much from error correction that it is better to stick to around 2100.
