- 29 Dec 2014
- The "North"
I'll try them at 550 to see if that helps. Not sure how I will do that as the ASUS Uefi shows everything in percentages to do with fans.I have sp120 too and aquaero 6 pro and I tried to reduce humming noise and I found that it's the best to run them at 550 I tried lower but humming becomes louder. I dont know if this are faulty fans or design issue. You can try to run them at this rpm, I find it to work for my. I got cm storm trooper windowed edition.
I was beginning to think this may be the soloutionLook, get quieter fans! There are plenty out there
To be honest I didn't realise they came with an adapter. I just assumed Noctuas were the only fans to come with themThose SP120 fans have a with step-down adapters in the box, have you tried using those?
