OK. Stepson #2 deciding that he couldn't wait, without at least taking the system image first, has upgraded his laptop (Asus X552CL) to W10.
The bad news is, that he has forced it by doing a clean install over his 8.1 OEM and now (quelle surprise) it won't activate.
Symptoms of the Patient
As far as I can see there are two options;
Somehow do a clean install of 8.1, upgrade, and then activate.
I did try this initially by using nirsoft to get the OEM 8.1 key, booting from my 8.1 DVD and trying to install. This failed, as the install software refused to recognise the OEM key I had extracted via nirsoft.
I suspect that I may have to try and convince someone in MS to activate his OEM key over the phone ? Not sure if that will work....
Convince MS to activate his W10 over the phone with a new key.
Not sure that this is doable at all. Might be my last shot before having to buy a license.
Am I missing anything ?
Thanks
- W10 says it is not Activated, otherwise works fine.
- Whilst there is a Windows.old directory there is no rollback option in Windows 10.
- The recovery partition appears to be borked, becuase when I boot from the ASUS recovery option (F9) I am unable to reset as the PC says the partition no longer exists, despite disk manager saying it's there and healthy (450Mb)
Thanks
