** ROG SEXYNESS: THREE NEW ROG SWIFTS COMING SOON!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK has a worldwide first on the brand new lineup of ROG Swifts, check the descriptions on the webshop and ETA's for updates as stock is severely limited and we do not expect shipments until at least November and possibly later.
For now admire the specification and how truly amazing these new screens look, of course those who pre-order right now will guarantee themselves one from the first batch but be warned you will be waiting 6-12 weeks approximately:
Asus PG279Q ROG Swift 27" G-Sync 165Hz IPS Gaming Widescreen LED Monitor - Black/Red @ £749.99 inc VAT
The Asus PG279Q Gaming display has a maximum supported resolution of 2560×1440, also referred to as WQHD resolution. For a majority of gamers, this particular resolution is the most preferred one because of the faster GPUs you can get nowadays. They aren’t powerful enough (at least one of them) to be sufficient for 4K gaming at high refresh rates, so 1440p at 144Hz will have to do. Refresh rate means a lot more than resolution for most gamers anyways, so that is not a problem. And to top it off, this monitor is capable of reaching a maximum refresh rate of 165Hz when G-SYNC is enabled. (Only supported on GTX 960 and higher)!!
OcUK expects first shipments of this absolute stunning gaming monitor in November, stock shall be very tight and we expect limited numbers so we advice pre-ordering as early as possible to avoid disappointment and to have a monitor before Christmas.
Features:
- Worlds first 165Hz panel with NVIDIA G-SYNC Technology
- 27-Inch, 2560x1440 2K/WQHD resolution IPS panel with superb 1000:1 contrast ratio, 350cd/m of brightness
- Super-narrow bezel design for seamless multi-display setups
- Asus exclusive 5-way OSD navigation joystick, GamePlus and 60-120-165Hz Turbo hotkey for an in-game advantage
- Ergonomic design with full tilt, swivel, pivot and height adjustment. VESA mount compatible
- Features a signature and mysterious base pattern with the illuminated LED light-in-motion on the chassis for ROG brand synergy
- DisplayPort, HDMI and USB3.0 Hub
Specification:
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: IPS
- Response Time: 4ms
- Refresh Rate: 165Hz (G-SYNC ONLY / GTX 960 & Above)
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DisplayPort & 1x HDMI
- USB 3.0 Hub
- G-Sync Enabled
- Warranty: 3yr
Notes/FAQ:
- 165Hz G-SYNC mode is ONLY supported on GTX 960 and above, GTX 700 series only support upto 120Hz!!
- 3x NVIDIA GeForce GTX660Ti BOOST GPU or higher in 3-way SLI configuration are needed, or GPU with 3x DP connectors for surround mode.
- Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.
NVIDIA® G-SYNC™ Technology only works with NVIDIA’s graphic cards. Other GPUs are NOT able to support this technology.
- NVIDIA® G-SYNC™ Technology automatically scales up your contents displayed to 2560 x 1440. The DisplayPort supports 2560 x 1440 up to 165Hz. The HDMI only supports 2560 x 1440 @ 60Hz.
- The ROG SWIFT PG279Q can support G-SYNC Surround (3x SWIFT PG279Q) up to 7680 x 1440 (*Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.)
- PG279Q does NOT support NVIDIA® 3D Vision™ .
- NVIDIA ® Ultra Low Motion Blur (ULMB) Technology works only at 85Hz, 100Hz, 120Hz.
Only £749.99 inc VAT.
ORDER NOW
Asus PG27AQ ROG Swift 27" 4k G-Sync IPS Gaming Widescreen LED Monitor - Black/Red @ £799.99 inc VAT
A lot of you have been waiting for a higher resolution version of our current ROG SWIFT the PG278Q. We have been hard at work designing and developing a monitor to meet the needs and wants of the ultra high-resolution gaming enthusiast. After spending sometime with the PG27AQ I think display enthusiasts are going to be pretty excited about this new addition to the ROG line of monitors.
OcUK expects stock to arrive around December of this amazing 4K Gaming Monitor from Asus ROG.
Features:
- 27-inch, 3840x2160 4K/UHD resolution IPS panel with NVIDIA G-SYNC technology, superb 1000:1 contrast ratio and 300cd/m brightness
- Ergonomic design with full tilt, swivel, pivot and height adjustment. VESA-mount compatible
- Asus exclusive 5-way OSD navigation joystick, GamePlus and GameVisual for an in-game advantage
Specification:-
- Screen Size: 27" (68.47cm)
- Resolution: 3840x2160 4K/UHD
- Panel: IPS
- Refresh Rate: 60Hz
- Brightness: 300cd/m
- Contrast ratio: 1000:1 (100M:1 DCR)
- USB 3.0 Hub
- G-Sync Enabled
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
Notes/FAQ:
- 3x NVIDIA GeForce TITAN X GPU in 3-way SLI configuration are needed for surround vision.
- NVIDIA® G-SYNC™ Technology only works with NVIDIA’s graphic cards. Other GPUs are NOT able to support this technology.
- NVIDIA® G-SYNC™ Technology automatically scales up your contents displayed to 3840 x 2160. The DisplayPort supports 3840 x 2160 up to 60Hz. The HDMI supports 3840 x 2160 @ 24Hz.
- The ROG SWIFT PG27AQ can support G-SYNC Surround (3x SWIFT PG27AQ) up to 11520 x 2160 (*Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.)
- PG27AQ does NOT support NVIDIA® 3D Vision™ . PG27AQ does NOT support NVIDIA ® Ultra Low Motion Blur (ULMB)
Only £799.99 inc VAT.
ORDER NOW
Asus PG348Q ROG Swift 34" G-Sync 100Hz IPS Gaming Widescreen Curved LED Monitor - Black/Red @ £1,199.99 inc VAT
ROG Swift PG348Q is a 34-inch gaming monitor with a curved 3440 x 1440 resolution IPS panel for immersive gaming visuals. This 21:9 aspect display has built-in NVIDIA G-SYNC technology and a 100Hz rapid refresh rate for ultra-smooth gaming visuals with no screen tearing or lag. ASUS GamePlus gives users four different crosshair options, an in-game timer and an FPS counter for an added advantage in first-person-shooter and real-time-strategy games; while ASUS GameVisual technology provides six preset display modes for optimized gaming visuals. ROG Swift has a frameless curved design that is perfect for an immersive gaming experience, and is ergonomically-designed with tilt, swivel, and height adjustments.
OcUK expects first shipments of these around December/January time, we expect limited numbers and pre-christmas delivery cannot be guaranteed at this moment in time until we get better leadtime from Asus.
Features:
- 34", 21:9 aspect ratio monitor with 3440x1440 resolution IPS panel for excellent visual performance
- NVIDIA G-SYNC technology and fast 100Hz refresh rate reduce tearing, stutter and lag during gameplay
- Frameless curved design for immersive gaming experience
- Asus exclusive 5-way OSD navigation joystick, GamePlus, GameVisualand Turbo hotkey for an in-game advantage
- Ergonomic design with tilt, swivel and height adjustment. VESA mount compatible
- Features a signature mysterious pattern with the illuminated LED light-in-motion on the chassis for ROG brand synergy.
- Built in 2W Stereo speakers
- DisplayPort, HDMI and USB 3.0 Hub
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Refresh rate: 100Hz (G-SYNC)
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 100M:1
- Viewing Angle (CR>10): 178/178
- Connectivity: 1x HDMI & 1x DisplayPort
- Speakers: 2x 2W
- Tilt: Yes
- Height Adjust: Yes
- USB 3.0 Hub
- VESA: 100 x 100
- Warranty: 3yr
Notes/FAQ:
- G-SYNC & 100Hz only supported on GTX 700, GTX 900 and Titan series.
- NVIDIA® G-SYNC™ Technology automatically scales up your contents displayed to 3440 x 1440. The DisplayPort supports 3440 x 1440 up to 100Hz. The HDMI only supports 3440 x 1440 @ 30Hz.
- The ROG SWIFT PG348Q can support G-SYNC Surround (3x SWIFT PG348Q) up to 10320 x 1440 (*Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.)
- PG348Q does NOT support NVIDIA® 3D Vision™ . PG348Q does NOT support NVIDIA ® Ultra Low Motion Blur (ULMB)
Only £1,199.99 inc VAT.
ORDER NOW
Asus truly innovating and bringing some truly immense gaming monitors. Surround mode on the 34" must look incredible but requires a minimum of three Titan X to run it. :eek: :eek: :eek:
Check our full range of G-SYNC Gaming Monitors
Hope these go well... that 34" UW will be a great product if it comes through. No way I would be spending that much on a monitor though, unfortunately.
nice monitors, but the price on the 34"swift is a bit silly.
Not at all!
I paid nearly £1000 over 5 years ago for a DELL 30" IPS, this 34" absolutely batters that DELL I paid £1000 for, better resolution, curved, higher refresh rate, looks far superior.
In my view monitors have only improved in value for what you get. :)
I don't fancy £700+ leaving my account for an item that's getting released in November at the earliest, especially after my own experiences of pre-ordering with OcUK.
Not at all!
no one monitor is worth over £1000. it should be £800 at most. just my opinion of course.
Meh tbh
Asus QC and cs is **** and certainly not worth the premium price tag that the likes of dell can demand
As for the 34" screen...
- iirc these are using the old panels that are used in the dell amd LG 34" IPS screens so they are being overclocked big time from 60hz like the acer screen (which acer actually state in their t&c that you have to do yourself and possibly void warranty)
- won't be surprised if they have back light bleed or\and severe IPS glow
- and of course stupid pricing, I would much rather put that towards a oled TV...
Meh tbh
- iirc these are using the old panels that are used in the dell amd LG 34" IPS screens so they are being overclocked big time from 60hz like the acer screen (which acer actually state in their t&c that you have to do not yourself and possibly void warranty)
But but but, it has deep, deeeeeeeeeep blacks!
