Downgrading to Windows 7
10 Aug 2015
4.6 miles away
Hi all,
I've installed a retail version of Windows 7 on a PC and upgraded to W10. The W7 product key is now allocated to W10.
If, after a few months, I decide to dump that PC can I use the original W7 retail disk and do a fresh install and use the same product key but NOT upgrade to W10 but keep it as a W7 system?
Thanks
The Boke
you can roll back to your previous OS within 30 days of doing the upgrade but if its after this point then a clean install is required.
you can roll back to your previous OS using your windows 7 retail key.
i have done this on a netbook which i upgraded to 10, after a month it had issues so had to do a clean install back to 8.1, all activated and fine on 8.1 but then tagged for W10 use at some point if the issues are fixed
Hi all,
Thanks
The Boke
Your old Windows 7 product key should still work yes, and as long as it is a reinstall and you are not using that key with an upgraded Windows 10 installation, it will legally be fine too.
Just to add something here.
When I downgraded a laptop from Win10 to Win7 my key was locked out. I needed to contact MS who admitted to me they had an ongoing issue with this. They gave me a new key in the end as they couldnt unlock my old one. Took 2 days to resolve but apart from that no harm done.
