Asus Z170 deluxe - wifi?
14 Dec 2007
Surrey, UK
I am looking at this MB for a new Skylake build. I won't be using wifi as I have a wired solution. I assume you can completely disable wifi? Dont need anything using extra power when I don't need it too.
Thanks for any help.
or you can buy the asus X99-S. It is basically a Deluxe board but without Wifi and 2 USB ports less. £50+ less as well.
