Stealing air
29 Jun 2004
No, we're not having a repeat of this gem:
Its an offense though. And could possibly be theft.
Wont the weight of the car possibly cause damage to the sidewall if flat
Can you get done for theft of someones air?
http://forums.overclockers.co.uk/showthread.php?p=26842327#post26842327
My thread is about going to a filling station, pumping your tyres up, and people coming up to you impatiently asking "are you finished with that mate?"; expecting to scrounge the few remaining seconds left in the air machine to fill up their own tyres after you have left. I don't like it. :p
I prefer if people let me pump my tyres in peace and didn't rush me.
I pay 50p at BP which gives 5 mins of air. Why? because nearest Sainsburys station is 12 miles away from me, BP is down the road, and there is always a mile queue at Sainsburys for the air, BP is always empty.
takes me half the 5 mins to do the job, dont really care if someone else uses it after me either.
I don't mind of people use the air machine after me and appreciate if I can use the air after someone else.
It's not at all in my interest to sponsor a big oil company/filling station.
Same as unattended toilets that require coins, obviously you share the toilet with anyone waiting there, friends or strangers.
Such things ( pumping air, toilets, etc...) should always be free, part of the serivce.
I often drive to a petrol station that has free pumping, only occasionally pay at the closest local Shell if I really have a flat and need it pumped asap.
Hey...
I was told by an ex Military policeman that it was an offence.. Although the offence "may" not have been stealing air but rather tampering with a vehicle. But hey ho. 6 of one and all that
I blow my tyres up the good old fashioned way.
As long as you have a tight seal around the valve, you can use either end - though the rear output is generally tighter.
:p
^I saw some weapon using one of those foot pumps at a Tesco filling station, whilst they were blocking the exit for all other cars.
Why not just buy an electric tyre inflator :/
Ok for an emergency but they are pathetically slow, and after 5 minutes or so of running the air coming out becomes stupidly hot. Much the same deal with a foot pump except after 5 minutes you figure you would have gone to the gym if you wanted a workout.
You just can't beat the speed and convenience of the forecourt compressor.
I'm being a bit OC about this, but it's recommended to check tyre pressures cold. If you drive to a petrol station they usually won't be cold anymore.
Most of the time my tyres don't lose much pressure, so I just use a foot pump with a decent pressure gauge. A couple of stomps is enough to top up any air that excaped while checking pressure.
Electric pump is in the car for if I have to top up a lot.
The only time the pressure's going to be low enough to actually require much of a top up is if thre is a leak (or a massive drop in air temperature).
Ergo I don't see why anyone would bother going to a garage forecourt for routine tyre pressure top ups. Surely a foot pump or electric pump are just as conveneint, if not more so?
