Let me use the 'HOME' and 'END' keys for Start / Stop Recording and dump last 5 minutes of Recording, the software doesn't recognize those Keys and its the ones i have been using for years in other recording apps.
What really annoys me is how it feels like they scam on the rewards, They had the 260x graphics card for 30 odd thousand so I saved and saved and did not spend a single point (I made sure too earn the maximum available points every day as well), just as I reached 30 thousand they removed the 260x leaving just the 270 for 80 thousand, I just know there gonna remove that card just before I reach it too.
It's like a scam they leave it there as a carrot just long enough (a year or so) for the people who save all possible points to almost have enough then they remove it so they don't actually have to give any away.
Not tested it but it might be possible to do it via registry edits:
HKEY_CURRENT_USER\Software\NVIDIA Corporation\Global\ShadowPlay\NVSPCAPS\ManualHKey0
HKEY_CURRENT_USER\Software\NVIDIA Corporation\Global\ShadowPlay\NVSPCAPS\DVRHkey0
Where the home key would be a value of 24 and end 23.
I Agree with the Raptr crap, it started out in life pretty good but now its just buggy junk bloat-ware.
They quality of AMD's VCE recording is better than Nvidia IMO but the fact that they don't have any 'in-house' software for it is a huge let-down.
As a tool and application Nvidia's Shadowplay is really good, it is exactly what AMD need to do.
Keep going with it, eventually you will have enough for the bigger GPU.
I would love it if that had steam integration with this.
I play on a couch and the only reason I don't use steam big picture mode all the time is because if I want to for example disable SLI for a game I need to quit out of big picture mode and open up my graphics settings.
I just wish you could do all this through steam big picture mode
