Don't install GeForce experience beta
12 Feb 2014
Just a warning - it'll force clock speeds down on your gpu (core clock set to 1130 down from 1500 and my memory was downclocked 600 from stock)
Yeah will do, something i forgot to add - in MSI afterburner it wont let you change the memory clock speeds at all, underclock, overclock, reset, nothing works so definitely that
Have Experience beta installed for a couple of days and don't have these issues or problems with clocks boosting. Installed update from the Experience prompt on W8.1.
Trouble with Nvidia forums is the lack of answers but plenty of issues being reported. If one solution solves this ternity I noticed it was to uninstall Experience and wait for the full release or go back to the previous version.
Nvidia made a lot of changes to recording/streaming that I felt was clunky (UI is huge for recording options and not easy to find old stuff until your dig into it) but checked it all out and it works. Was testing out Crysis 3, Witcher 3, BF4, and boost never dipped below 1350MHz as it peaks at 1440Mhz-ish - ample performance for 980 Ti's.
Yeah I uninstalled and reverted back to the release version and all working fine. Could be from streaming. Memory clock sitting at 3300 compared to 4000mhz in osd wasn't right! Maybe it just conflicts with it?
Noticed it happened after I started streaming. Have you tried that yet ?
I was running w10
No issue here with the Beta and Andy, it is still there and set to your hotkey but doesn't have the symbol in the bottom right like before for some reason. Press your normal record key and it will start recording.
lost the shadow play function when installed the beta
To access recording options click the Share button to set up the recording options there.
You need to enable Instant Replay for capturing recent gameplay as it disables this on this beta. A simple matter of clicking to enable and setting up res, data rate, length of replay.
As Greg said the hotkeys are the same. Go to Preference and Share and your hotkeys are there.
