Help with extension wiring for broadband please
18 Aug 2012
Hi all, my BT infinity has been activated today and been working great. I have connected my router on one of the extension sockets in my room(quite far from the master socket - internal wiring) and I received connection speed of 64mb down and 20mb up.
I then tried the master socket and the connection speed was 80mb down and 20 up straightaway. So obviously there is a problem with the extension wiring.
I was thinking of buying extension cable maybe around 25m and connecting that to the master socket. Will this likely to give me better connection than using the internal wiring as some of the wiring are quite old.
Many thanks,
Better to have the router connected to the master then use an Ethernet cable to connect between the router and a small network switch in your room.
because my master socket is far from my room and i will have a very week signal thats why i have the router in my room as i have ps4, my PC, sky box.
i have BT home hub 5 as i am using netgear D7000 atm.
PS: just to clarify im getting the full 80mb speed when connecting to the "test socket" rather than the master socket that covers the test socket. Does that make a difference? can i still connect an extension cable to that.
You have other telephone outlets around the house then ?
If you get full speed in the test and reduced in the master as you call it then that suggests an internal wiring issue.
Did OR change the master socket when you upgraded to fibre ?
We have got 7-8 sockets in the house. Thats right full speed in the test socket and a much reduced speed in the master socket.
I didn't change as unfortunately i wasn't aware of the fault, otherwise i would have booked an engineer.
Sounds like the extension wiring is acting as an aerial and picking up interference. Put a vdsl filtered faceplate on the master socket and then the extension wiring will be isolated from the broadband filtering. You won't need to put dsl filters on all the telephone extensions then either.
That won't let me connect my router to extension, will it ?
7-8 is that telephone extensions?
Keep your router next to the master socket, use a short cable (0.5 to 1M RJ11, ADSLNation)
From here run a network cable to a central switch and from that run cables to each room. Add wireless access points as necessary
impossible, some of them are internal. I think my only option is to connect router to the master sock and a run a cat5e to my room.
I have not seen it but why can you not pull other cables using the current ones even if it's say only one of them?
A long cable from the master is the best option.
Did you have an Openreach engineer do your BT Infinity install?
