** LG 34" 3440x1440 IPS CURVED, NEARLY HALF IN PRICE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
October last year we launched the amazing LG 34UC97, I am still using mine right now, absolutely gorgeous monitor. We sold nearly 1000 of these stunning screens last year and they were also practically £1000 each. :eek:
Today we launch the exact same monitor but without Thunderbolt connectivity, the result is compared to last years launch price of £989.99 we are able to offer the none Thunderbolt version at just £659.99, the screen is identical in every way and at this price is a great deal for such a stunning display.
LG 34UC97C 34" 3440x1440 IPS WideScreen Super-Wide Curved LED Monitor @ £659.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC97 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort
- Speakers: 2x 5W
- Tilt: -5 / +15
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Linus Review:
- Warranty: 2yr (LG - 0344 847 5454)
Only £659.99 inc VAT.
ORDER NOW
LG 34UC97-S 34" 3440x1440 IPS WideScreen Super-Wide Curved LED Monitor @ £749.99 inc VAT
34UC97 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC97 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Specification:-
- Panel Type: IPS
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 5W
- Tilt: -5 / +15
- Weight: 8.2kg
- Linus Review:
Was [£799.99] Inc. VAT
Only £749.99 inc VAT.
ORDER NOW
We expect our stock to land early next week. :)
VIEW OUR FULL RANGE OF CURVED MONITORS!!
£659.99 = NEARLY HALF IN PRICE??
Surely it would be a lot more accurate to say a third off?
£989.99 * 2/3 = £659.99
£989.99 * 1/2 = £495 (to the nearest penny)
Just because £990 is 50% more expensive than £660, doesn't mean that £660 is 50% less expensive than £990 ;)
So it's basically the same price as the Dell U3415w which uses the same panel, has a better stand, and better support?
Trains A and B are traveling in the same direction on parallel tracks. Train A is traveling at 60 mph and train B is traveling at 70 mph. Train A passesa station at 12:20 P.M. If train B passes the same station at 12:32 P.M., at what time will train B catch up to train A?"
:D
I'd buy the DELL. ;)
But the LG's sell quite well. :)
Can't recommend this form factor enough.
Picked my Dell up for roughly this price and I love it!
Does the curve actually make any difference, for better or worse?
It's subtle, like, so subtle you forget it's there. (imo this is a good thing) - I couldn't imagine using this form factor on a flat monitor though.
After using the Philips 4k 40" monitor for a while I can see why the curve would be advantageous, not been able to see a curved on in person yet. Any news on if anyone is working on a curved 40"er?
