If you've damaged the headphone socket you may find that with a small hook you may be able to pull the contacts back towards the jack to improve the contact. Is the socket replaceable?
When I got my GF's fractal design case, the headset socket didn't work. I contacted them and they sent me a new replacement panel (which also had usb and power buttons on) A few screws later and it was swapped out!
What case is it? Maybe you can contact the manufacturer and see if they will give you a replacement FOC (if they are kind) or let you purchase one.
