Permabanned
- 3 Jan 2015
While I am trying to sell it, I have been playing around with a old computer I built for general use and my movies at the time.
Asus board I think(socket 754)
Amd sempron 3000+ 1.8ghz with stock cooler
2gb ddr ram
GeForce 310 512mb
500w cit psu(brough cit case and of course psu included)
I have always tried a little overclock but this time I thought I will try it out a bit more proper. Crysis was my test game as probably best of what I got to push and while it ran on stock it was awful, then I upped the bus to achieve 2.0ghz and pushing the 310 upwards of 50mz on clock and memory(only 2 options available) in different stages it played better but not great, all settings were on low with the odd medium.
Now after a couple blue screens and some stability issues going to 2.25ghz I upped all the vcore 1 click to make it stable, don't know if I needed to do all, but did anyways, after couple issues with slow boots and graphic issues(probably pushed GPu too much or a driver thing) it all seems to working better and boots more normal, gpu is like 700mhz and 600mhz, nearly at max and crysis works on both low and medium settings with lag, but playable..
3dmark also does the ice storm test At like 35-55fps until physics and maybe odd section of test 2, and that's with 6100 onboard graphics as 310 has driver issue with the programme, but being a dx10 system it can't do the other tests.
Now if I don't end up selling it I will do further testing as its quite interesting and fun, but will go with the cpu cooling first maybe as I don't know what the psu can push(gt 430 maybe), but with so much choice from £5 I don't know what would be improvements over the stock cooler..
2gb ddr ram
GeForce 310 512mb
