Asus RT-AC3200 Tri band Wireless AC3200 Gigabit Router @ £189.95 inc VAT
Intelligent Tri-band Wi-Fi for All Your Devices
RT-AC3200 is a tri-band 802.11ac router featuring Tri-Band Smart Connect, an incredible new feature that automatically maximizes the performance of each and every wireless device. With the world's fastest combined data rate of 3200 Mbps (2600 Mbps on the two 5 GHz bands plus 600 Mbps on the 2.4 GHz band), RT-AC3200 allows every device to work at full speed, ensuring lag-free online gaming, silky-smooth 4K/UHD video streams, and effortless downloading. Add to this superb coverage and total security, and you'll see why RT-AC3200 takes your network to the next level!
Revolutionary Hardware
Six external high-performance antennas
RT-AC3200 uses two 802.11ac networks, each with a three transmit, three receive (3x3) antenna configuration. This is made possible by its six external high performance antennas, and allows more devices to connect faster with better stability.
Dual USB ports
The easy-to-use USB app lets you share printers, storage devices and 3G/4G (HSPA+) dongles over your entire network, and the SuperSpeed USB 3.0 port ensures ultra-fast transfer speeds. Plus, there's plenty of space around each port to accommodate bulkier devices.
Smart Connectivity For Full-Speed Networking
With more and more Wi-Fi devices competing for bandwidth on home networks, ranging from slower legacy devices to the latest 802.11ac products, there's a real need for a smart way to make sure every device is working at full speed. RT-AC3200 uses tri-band Smart Connect technology to do just that, along with AiRadar universal beamforming for enhanced Wi-Fi coverage and stability.
Tri-band Smart Connect
Our Tri-Band Smart Connect technology automatically assigns each device to either the 2.4 GHz band or one of the two 5 GHz bands, according to the device's speed, its signal strength, and how busy each band is. This means you never have to decide which band to use, as RT-AC3200 does it all for you. This means you get better range and faster, more reliable connections — all the time!
AiRadar beamforming
ASUS AiRadar intelligently strengthens wireless connectivity using 802.11ac universal beamforming technology, high-power amplification and exclusive ASUS RF fine-tuning.
Adaptive QoS
ASUS Adaptive Quality of Service (QoS) optimizes and prioritizes bandwidth, with presets for gaming, media streaming, VoIP, web browsing and file transfers.
Powerful online multitasking
RT-AC3200 has a data pipeline that's around 20 times larger than conventional routers — up to 300,000 data sessions — for exceptionally smooth performance.
Life In The Fast LAN
For the fastest wired networking performance, RT-AC3200 has a dedicated Gigabit Ethernet WAN port plus four Gigabit Ethernet LAN ports. Its powerful hardware-accelerated NAT removes the bottleneck between the wired LAN and the internet for a lag-free gaming experience.
Hardware NAT
Removes the bottleneck between the internet and the home network, giving WAN-to-LAN performance that's between 2-5 times faster than a traditional software-based NAT.
Dual WAN support
Configure one of the LAN ports as a WAN to use two internet connections, either to share internet traffic between them or so that one can be used as a backup connection should one connection fail.
Tested For Compatibility
RT-AC3200, like all ASUS networking products, is subjected to exhaustive compatibility testing during its development. RT-AC3200 works flawlessly with a vast range of adapters, media players and other wireless devices to ensure the best performance — it even supports the latest-generation Xbox® One and PlayStation® 4 game consoles.
Time Machine® support
Any USB storage device attached to RT-AC3200 can be used in conjunction with Time Machine® backups for your Apple devices.
WPS
Any device supporting the Wi-Fi Protected Setup (WPS) standard can be connected instantly simply by pressing the WPS button on RT-AC3200.
VPN support
Create a VPN server or turn your network-connected devices into VPN-enabled clients — with no need for paid VPN services.
The Powerful, User-Friendly Interface
ASUSWRT
RT-AC3200 features the enhanced ASUSWRT graphical user interface, which gives you easy access to the 30-second, 3-step web-based installation process3. It's also where you can configure AiCloud 2.0 and all RT-AC3200's advanced options. ASUSWRT is web-based, so it doesn't need a separate app, or restrict what you can change via mobile devices — you get full access to everything, from any device that can run a web browser.
Adaptive QoS
Traffic Analyzer
Traffic analyzer helps you spot internet bottlenecks quickly and easily. It gives you an at-a-glance view of the amount of network bandwidth used by each user, device or application on a daily, weekly or monthly timescale.
Network map
Comprehensive network map shows you at a glance details of what devices are connected to your router and their connection status.
AIProtection With Trend Micro™ For Advanced Security
AiProtection, incorporating state-of-the-art, three-pronged security from Trend Micro™, gives you enterprise-level security in the home — it's one of the most secure home routers you can buy! It constantly monitors the health and safety of your network for total peace of mind.
Router security scan
Scans your router for any security vulnerabilities and recommends options for improving protection.
Malicious site blocking
Restricts access to known malicious websites in the Trend Micro™ database for always-up-to-date protection.
Vulnerability protection
The Deep Packet Inspection (DPI) engine gives complete protection against common internet-based attacks and exploits.
Infected device detection and blocking
Prevents infected devices from communicating personal information and/or infected status to external parties.
Web and app filters
Keyword and URL filters to block access to unwanted websites and apps.
Time scheduling
Schedule time limits for specific guest accounts and devices.
Create Your Own Personal Cloud
ASUS AiCloud keeps you close to your data wherever and whenever you have an internet connection. It links your home network and online storage service4, giving you access to your files using the AiCloud mobile app on your iOS, Android smartphones or via a personalized browser URL. You can share photos instantly to services like Facebook, Flickr or Dropbox directly from the AiCloud interface. Even better, AiCloud can be connected to another compatible router to expand your personal cloud even further.
Only £189.95 inc VAT.
ORDER NOW
View the whole range of cable routers here
Dual USB ports
AiRadar beamforming
Adaptive QoS
Hardware NAT
Dual WAN support
WPS
VPN support
ASUSWRT
Adaptive QoS
Traffic Analyzer
Network map
Web and app filters
Time scheduling
ORDER NOW
