** DUCKY **
rjk
rjk
OcUK Staff
8 Aug 2007
We have stock now of the new Blue and Black case Ducky ONE keyboards.
All our boards are UK ISO layout with the big enter key.
We also have stock of the fantastic new desk mat from Ducky too!
Check out the full Ducky Range Here
Ducky Flipper Extra, Mouse Surface - Black @ £19.99 inc VAT
The Flipper is a great all in one desk mat from Ducky designed for optimal performance with their upcoming mouse and their range of high end mechanical keyboards
Specifications:
- Colour: Black
- Dimensions: 800X350X3(mm)
- Material: Jersey Cloth
Only £19.99 inc VAT.
ORDER NOW
Ducky One Mechanical Keyboard, Brown Cherry MX Switch, Blue LED, Black Case, UK Layout @ £99.95 inc VAT
Ducky One is designed with narrower bezel compared to previous Ducky keyboards, the thinnest bezel that they have ever made. Ducky have reduced the overall size without affect the overall design of the keyboard. The keyboard looks much better with modern, simple and minimalistic design.
The Ducky One has a unique two stage foot design that allows end users to optimise the height of their keyboard for maximum typing comfort.
Ducky One uses Micro USB connections on the rear of the board and features cable guides to allow the user to decide where the cable comes from to avoid clashing with other desktop peripherals.
The One comes with ABS Double-Shot premium Keycaps. This is the first model from Ducky that features a double shot ABS plastic on the keycaps. The double shot method combines two different colours of plastic that separate the Keycap surface and the Character on the keycap. This allows for the LED backlighting of the Ducky One to shine brightly through the surface of the keycap. This also means that the keycaps are much more hardwearing and will not go shiny or lose the character like a traditional painted ABS keycap featured on most other mechanical keyboards and cheaper keycap sets.
The Ducky One uses genuine Cherry MX keyboard switches alongside a dual layer PCB design for longer life expectancy and signal stability
The Ducky One features a host of Backlighting Effects including:
- 100% Full Backlight Mode
- Breathing Mode
- Raindrop Mode
- Reactive Mode
- Ripple Mode
- LED Zone Customization Mode
Specification:
- Switch: Cherry MX Brown Mechanical Switches
- Interface: USB 2.0
- 1000Hz Report Rate
- Simultaneous key input: USB N-Key Rollover (NKRO)
- USB Repeat Acceleration
- LED: Single Color LED
- Keycap Material: ABS
- Legend printing:Double shot or Laser engraving
- Dimensions:440 x 140 x 41 mm
- Weight:1.3kg
- Origin of Production:Taiwan
Only £99.95 inc VAT.
ORDER NOW
Ducky One Mechanical Keyboard, Brown Cherry MX Switch, Blue LED, Blue Case, UK Layout @ £99.95 inc VAT
- Breathing Mode
- Raindrop Mode
- Reactive Mode
- Ripple Mode
Specification:
- Weight:1.3kg
ORDER NOW
Tempted with the mouse "surface"
I cut my XXL overclockers pad to around 70x25 (perfect size for TKL keyboard + mouse)
Does it have a similar texture to your mouse surfaces?
Still waiting for Ducky to do a TKL like this.
Chop the num pad of and knock £20 of the price, and you have a sale.
That blue case is very sexy though.
Might be a good idea to get Ducky to do a deal for keyboard+mouse surface together as-well.
This is an old thread. All the images are linked to our old site. We will have a new post generator sorted soon enough but fixing that is low on the priority list when the new site is being improved and having all the initial stuff ironed out
Old thread however.
Theres a new ducky one non backlight version out, will you be getting any in? If so any idea on cost?
we will have any new ducky skus available in UK layout.
as soon as they are available, they will be on ocuk.
