What to use for drain port/tube please?
Permabanned
9 Oct 2006
Hi all, I had to drain my loop recently and lets just say not having a drain configuration was...troubling, so now im looking to install one, my thinking for most convenient would be some kind of splitter coming off the lowest point of the loop into a tap thats plugged, such as the Bitspower mini valve which seems perfect for what I need, but! I cant seem to find any splitters to split the loop out, so does anyone have any recommendations or ideas? I will be looking to "tuck it" away somewhere so it will have to be a tubing setup of some kind that I can just use when necessary, thank you for the help! :)
What parts do you currently have in your loop?
XE 480 at the top, XE 360 at the bottom and an XE 240 at the front, the 240 has its ports on the lowest part of the radiator so I was going to split off of that since its the lowest part in the loop then, my pump/res is a photon which is mounted slightly higher than the 240
And thank you for the XSPC T fitting link! :)
