win 10 Email app killed my pc lol
Permabanned
6 Feb 2010
Barnsley
ok so i had a pal over and he wanted to show me an email he as received so we used the win 10 app for mail......
My pc in now LOCK to his mail, i need to used his email password ever time i log in.
microsoft give you one option to fix this.
Start > Setting > update & security > Recovery > RESET
That right there only open is a full system reset.
Do we have any idea to fix this or do i have to just go back to win 7?
Go back to Windows 7 :P
Slightly more helpful you might be able to revert it with minimal/no loss by using an older restore point maybe - I can't see a way to revert an account other than to switch to a (new) local account, doesn't even seem to have the "disconnect an account from a MS ID" option any more - but not really an area I'm overly familiar with.
Try going to:
Control Panel > User Accounts > Credential Manager.
Then select Windows credentials.
Under generic credentials select the 'MicrosoftAccount:user' and have a fiddle.
Under Other items look at SSO_POP_User and have a play.
I don't use Windows10 mail app, so there might be another entry under there, have a look :-)
Also check Web Credentials option as there are some logins on there :-)
Good luck.
Slightly more helpful you might be able to revert it with minimal/no loss by using an older restore point maybe - I can't see a way to revert an account other than to switch to a (new) local account,.
thats the one i went back to a new local account, all my fiels are still intact too.
