Well if you want the really good stuff then you won't let the cabinet depth stand in tour way.
Hello jigsaw![]()
Alas it's a living room first and foremost
Sony 1050 would fit
Hello jigsaw![]()
Any amp would fit if you cut out the back of the cabinet. But it sounds like you've already made your mind up.Alas it's a living room first and foremost
Sony 1050 would fit![]()
I'd have to disagree unless your idea of (simply) chopping the back out of the cabinet includes gauging a square foot of brickwork out from the wall the cabinet is fitted toAny amp would fit if you cut out the back of the cabinet.
NiceBut it sounds like you've already made your mind up.
That's the first time you mentioned that the cabinet is fitted. Though not unheard of, it is less usual on a living room. But yes, that does present something of a challengeI'd have to disagree unless your idea of (simply) chopping the back out of the cabinet includes gauging a square foot of brickwork out from the wall the cabinet is fitted to![]()
Not sure what the need for the rolleyes is all about?Nice
I unfortunately have a depth limitation it seems of approx 33cm which some manufacturers don't like limiting themselves too.
Nice view up there from your moral high-ground with your 20-20 hind-sight?If you're reading more in to a comment than is actually there then that's up to you.
You've come on and asked what's the best way to achieve something. The good people here have donated their time and expertise to help you despite working largely in the dark about the gear you own and your wider objectives and restrictions beyond the basic bits of information we have coaxed you to provide.
Yes, you might be inexperienced; hence the request you made for help. In return the people her have explained the pros and cons of each approach, and more importantly, we have also given you some insight beyond satisfying your immediate requirements so that you can plan for the future, or at least to be able to say that you've considered those options. I think that that is incredibly valuable advice. Imagine having that sort of level of foresight when planning to install fitted cupboards in the lounge. You might say that they were already installed when you bought/rented your home, which is fair enough, but we wouldn't know that unless you volunteered the information. It's up to you to include relevant information and why it affects your product choices. That's a simple courtesy when people are giving you their time and the value of their expertise to help you with your problem.
