AMD R9 Fury X Could Be Impacted by Liquid Cooling Lawsuit
Liquid cooler manufacturer Asetek, the company that supplies many of the industry's best-known coolers by Corsair, EVGA, and NZXT, saw victory in a patent infringement case against Cooler Master (CMI) in 2014. In that trial, the jury awarded Asetek a 14.5% royalty on all Cooler Master liquid coolers sold in the US.
The trial can be boiled down to Cooler Master's usage of a coldplate-mounted liquid cooling pump, something for which Asetek holds a patent. Cooler Master's Seidon, Nepton, and Glacer liquid coolers use a pump atop the cold plate, which the court ruled to be patent infringement committed against Asetek. Cooler Master also makes AMD's R9 Fury X liquid cooling solution, which has interesting possibilities for the AMD product; it is yet unclear if the Fury X will be affected by the court ruling against Cooler Master, but the design is similar enough for there to be concern. The Fury X CLC hosts its pump atop the coldplate, which is the heart of these patent lawsuits.
