Do you reckon all the cocks in the outside lane of the motorway will now switch back to BMW's?
They'll be in all lanes.
Hopefully we'll see a greater number of decent petrol motors now. Second hand market is saturated withtractor engines. Been looking for a decent petrol saloon but its much trickier than it used to be.
If this means a reduction of diesel vehicles on the road so much the better.
They should have banned diesels from cities ages ago in my opinion.
Many modern petrols now are economic, low emission, and that little bit more pleasant to drive, and less noisy as well as cheaper to maintain (diesels tend to be expensive to look after).
Genuine question, are diesels really that much more expensive to look after, or is it just all of the extra technology that's bolted on for economy and emissions? Surely small modern ultra-eco petrol engines with tiny turbos etc are going to be just as complex (and therefore expensive to fix/run) as turbo diesels?
Yes. Much shorter time between services/oil changes. And all that technology used to keep emissions down breaks often and is very expensive to fix.
And for the same performance, diesel cars cost more to buy in the first place.
It used to be that you could save money running a diesel over a petrol without doing massive miles per annum. Last time i did the calcs it was almost 25k per year you needed to do to be better off with a diesel. I suspect it will be even more now.
But try telling my father that who buys a new diesel every two years and does 4k per annum
Some people (Myself included) prefer the way a diesel drives.
Not sure where you get your calculations from but I do ~15k miles per year and the cost of running a petrol over a diesel would cost me close to £800per year with increased fuel and tax costs. A petrol version of my car would be £350 cheaper brand new but over 3 years of ownership will cost me well over ~£2400 extra to run. So in the long run getting a diesel saves me ~£2000.
Real MPG numbers for my car
1.6T Petrol ~37 MPG
1.5T Diesel ~54 MPG
~46% better fuel economy and zero road tax (£130 for the petrol). So while going diesel for low mileage is lunacy it does make a difference from significantly less mileage than 24K.
Normally the price difference between diesel and petrol is around £2k. Then dont forget to throw in all the extra services and the extra cost of them.
