Hey everyone.
I decided that I would post my project on the forum just because I figured it was time for me to give back a little. My primary reason for this PC is game development with a secondary use for gaming and web design.
My last build was in an antec 900 with a custom loop (my first watercooled rig). I learned a few lessons from it which should help me here a little
The Parts I have ordered are
1x EK Water Blocks EK-FC Titan X - Acetal+Nickel
1x EK Water Blocks EK-FC Titan X Backplate - Black
6x XSPC G1/4" 90 Rotary Fitting (Black Chrome)
1x XSPC Photon 270 Res
1x Nvidia 980Ti (ref board)
3x Mayhems Aurora 2 Red 1ltr
4x XSPC G1/4" 45 Rotary Fitting (Black Chrome)
7x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome)
3x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length]
2x XSPC G1/4" Plug (Black Chrome)
1x Phanteks Enthoo Primo (Green / Black)
1x Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 CPU
1x MSI X99A SLI Plus Intel X99 (Socket 2011) DDR4 ATX Motherboard
1x Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Kit
1x Microlab SOLO8C 120W RMS - TOSLIINK - Stereo Speakers.
1x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply
1x Coolgate CG280 280mm Radiator - Black
2x Phanteks PH-F140XP PWM 140mm Fan - Black / White
1x Arctic Silver 5 Thermal Compound (3.5g)
I will be using some of the previous parts from my older computer.
These include
1x XSPC Pump/Res Combo (Mounted in Bay)
1x XSPC rad (380 I think) - Will confirm
1x Dvd Combo
1x XSPC Raystorm CPU Block
And then I have now ordered more stuff after I decided to put a quick drain port on.
1x Koolance QD3 Male Quick Disconnect No-Spill Coupling, Panel Female Threaded G 1/4 BSPP Black
1x Koolance QD3 Female Quick Disconnect No-Spill Coupling, Male Threaded G 1/4 BSPP - Black
2x Bitspower Multi Adapter IG 1/4 Inch - Carbon Black
1x XSPC G1/4" T Fitting (Black Chrome)
These are my revised plans for flow and cooling.
Some of the parts have been delivered already but I am still waiting for many of the WC parts so I will update this post with images and the such once I have some info to share.
So I have some of the parts now so getting an idea of the space in this case... its nice!
I have dumped in most of the components now but still waiting for compression fittings.
These include
1x Dvd Combo
