Two fast SSDs?
Get a quad channel RAM kit to make full use of the quad channel memory controller.
You might find that the Asus GTX 970 doesn't fit in that case due to the heatpipes. The MSI GTX 970 doesn't fit because of the same reason.
Thanks for pointing that out, might have to take another look at cases.
Also the EVGA G2 is a bit cheaper and you get a longer warranty. It is essentially the same psu (Same manufacturer and platform).
YOUR BASKET
1 x evga supernova g2 850w '80 plus gold' modular power supply £114.95
total : £124.55 (includes shipping : £8.00 ex.vat).
fractal design do a matx cube case although it is a lot bigger than the air 240.
your basket
1 x fractal design node 804 micro-atx case - black window £78.95
total : £88.55 (includes shipping : £8.00 ex.vat).
review - https://www.techpowerup.com/reviews/fractal_design/node_804/1.html
I have that case and only 970 I found that fit was the OCUK reference one and that is pressing against the window.
