Also, does anyone know what the crack is with the round altar/platform with the green liquid/gas pouring of it is? There's a chest on it iirc.
Yep, am up for that. I can be sat there with my ghost out on the bridge and as you land on a platform I'm on, can jump to the other so you kbow where it is I guess? Will have to see how it works.
Give me a shout when you're going to run the next part cause I have it to do as well.
So I got the sword after farming those Hadium Flakes.
and its much worse (attack wise) than the Machine gun and rocket launcher I have.
are there other quest bits to this? or was it really not worth the time?
You on about the quest to kill the dude on the dreadnaught? Already done it, it's pretty easy to solo.
After that step you have this horrible grind....get 10 rare materials and 500 ish ability kills....not fun
Nope, you need all 3 exotic swords if you want one of each type. There are apparently a few glitches you can do to make the quest a bit shorter though.Does the exotic sword have the ability to change elemental damage on the fly? I don't fancy going through this rigmarole with the other two.
Wednesday, it's the day the gunsmith gets new stock and weapons to test.
Yup, at rank 3 you get a quest for your classes exotic weapon
