How far is this VW thing going to go?
If this means a reduction of diesel vehicles on the road so much the better.
They should have banned diesels from cities ages ago in my opinion.
Many modern petrols now are economic, low emission, and that little bit more pleasant to drive, and less noisy as well as cheaper to maintain (diesels tend to be expensive to look after).
genuine question:
spec me a petrol estate that does 50mpg+, capable of doing 400miles+/week and isnt completely gutless (with and without a load).
I know very little about adblue. What happens if you want to save money by simply not topping it up?
Check engine light, 20 restarts, 21st attempt no engine start based on emissions failure. With NOx sensors downstream it knows whats going on if you fill like system with just water (like the truckers do on the Gen1 systems)
genuine question:
you're missing the point of this thread. the fact is diesel fuel is very dirty fuel and its very hard and expensive to get them clean. there is no future for diesel
to answer your question
cheers
He's talking about city driving though where I doubt you'd need an estate to be doing 400miles+/week.
sorry wasn't sure if it was about cities or generally.
i dont think so. people are calling for an end to diesel but for a lot of people its clearly the best option.
You mean, if they are still running in 7-8 years?
Exactly.
I wonder how much pollution is really reduced by essentially halving the usable life of a huge number of cars in order to reduce their emissions?
One of the main reason the diesels are successful is because they run slower, cooler in general, and thus last a LOT longer than petrol ones... Thats why taxis for example wouldn't dream of getting a petrol car, and it's been the case for years...
Indeed - I don't think diesel engines are inherently more complex/harder to maintain than petrols, it's all the extra bits bolted on - turbos, DMFs, DPFs, etc. which make them so.*
Start bolting all that tech onto petrol engines, and surely you'll end up with the same effect?
It's going to be "interesting" buying a used car at the bottom end of the market (e.g. £1-2k range) in 10-15 years!
*I'm not a mechanic, so by no means an expert, so please correct me if I'm wrong :)
You mean, if they are still running in 7-8 years? One of the main reason the diesels are successful is because they run slower, cooler in general, and thus last a LOT longer than petrol ones... Thats why taxis for example wouldn't dream of getting a petrol car, and it's been the case for years...
This is generally not true - it was the case perhaps 20 years ago when diesel engines were inherently simple and hardy but modern engines have a plethora of complex ancillary components to ensure they meet (or not, lollll) both emissions standards and consumers increasingly high expectations around performance, economy and refinement. As a result the potential for failure is generally higher amongst diesels and a surprising amount of taxi's are now petrol as a result.
In countries without high fuel price almost nobody drives a diesel - especially taxi drivers.
You can't honestly be serious. About 1/4 of the taxis around here are petrol now.
And factor in more and more cities are banning diesels full stop and you soon wont be able to go places with your diesel cars.
Before this all kicked off there were talks about banning or restricting diesels in 6 major uk cities by 2020 due to Nox. This will only speed up that process.
I saw somewhere it was going to be a £12.50 per day charge for Birmingham for example.
Any fuel savings are going to be more than wiped out.
Maybe the Qashqai is just a rubbish example of what petrol engines can do :p
http://www.honestjohn.co.uk/realmpg/ford/fiesta-st-2013
85bhp and 73lb ft more than the Nissan and it only weighs ~150kg less yet gets the same "real world" economy...
None of which refutes my point that Greedo's claim you need to do 25K miles per year before a diesel cars saves you money is not (always) the case. I have proved my point with figures, if you want to ignore them based on nothing more than feeling go ahead.
Regardless oh how much you prefer petrol, or want to denigrate diesels (or my choice of car), it does not change the fact that diesel is a much more viable option for many drivers.
Agreed clearly there are some cars were the diesel economy (real life) vastly outweighs the purchase cost and running costs of the petrol version.
As always it should be looked on an individual case.
You haven't proven anything with your figures - maybe you missed my post but the "realmpg" figure for the 1.5 Diesel seems to have a sample size of 2 - hardly representative.
That site is hardly "fact" though is it - it doesn't show the sample size for a start - so the 1.2T could easily be only 3 owners figures (e.g. 34.0 and 45.6 are already known - a 3rd entry of 36.2 would give a 38.6 average).
http://www.honestjohn.co.uk/realmpg/nissan/qashqai-2014/12-dig-t
Similarly the Diesel 1.5 figure conveniently averages out to 53.3 with just the minimum and maximum of 46.0 and 60.6 - again 2 samples is hardly representative.
http://www.honestjohn.co.uk/realmpg/nissan/qashqai-2014/15-dci
How about fuelly.com?
Has a larger sample size for both 1.2 petrol and 1.5 diesel Qashqai 2014. While the sample sizes aren't massive they are still figures based on actual real data.
1.2T petrol: 38.5 average MPG.
1.5T diesel: 54.3 average MPG.
Both numbers are based on averages and I accept it all depends on driving style but my point stands. Depending upon vehicle, it takes considerably less annual mileage than 25,000 before a diesel becomes more economically viable in the long run.
[TW]Fox;28620890 said:
As a result the potential for failure is generally higher amongst diesels and a surprising amount of taxi's are now petrol as a result..
Yep the DPF has them swinging back the other way. The last thing you want is a dpf diesel as a taxi driver unless you are doing constant long airport runs. In the same way driving instructors have ditched the Diesel Corsas for something petrol based again. :D
