EVGA GPU With MSI Afterburner ?
19 Feb 2007
Northampton
Would I run into any problems running a 980 Ti Classified with MSI Afterburner like not being able to use certain voltage controls etc... ?
What Voltage Controls do you get in Precision-X that you don't in AB?
I aint got a clue, I was just curious seeing as the Classified is a custom 980 Ti and if it's anything like the Asus Matrix line another set of options opens up in Asus GPU Tweak :)
I Have a Gigabyte GPU and OC Guru is crap. :D
I have tried Precision-X but didn't like it, too busy for me and i'm too used to MSI AB, i think.
I'm always curious for features myself but couldn't see anything on Precision-X that AB doesn't have, i think it has or may have some sort of voltage locking to stop it from throttling if you have an EVGA GPU, tho i think AB has a similar thing in "Force constant voltage"
I'm not sure you would want to run a Maxwell GPU with pegged volts 24/7, if its throttling its doing it for a reason.
Other than that AB seems to have everything you need, certainly everything i need.
