If you already have a 980 then buy another used 980 and sli. Wait for pascal to come out and upgrade both cards then![]()
As sli 980ti's would cost you around £250-£300 more than a TX if buying new.
980ti sli mullers a TX.
I can't understand why SLI and X-fire options keep being stated, OP is asking for a "Single card".
I think we all already know the answer is the TX, if the title read "What's the most cost effective way to get 4K @ 60fps" then that would be a different story/thread.
As title really I have a 980GTX and seems ok on high but what graphics card play on ultra.
Games like
Gta 5
One card to rule them all, the TitanX.
Not the best bang for buck but it is the king of 4k or 8k for that matter.
Watch out Ti fanboys, 6gig Vram won't cut 4k for much longer.
8gb is easy to breach now @2160p
Disclaimer
I am typing this on a non NVidia PC.![]()
One paper sure no one can rationally debate otherwise. But, as it stands with the TX being a reference only card unless you go water it isn't. If you are going to add waterblocks etc then yeah it's got that tiny bit more grunt but because the TX only comes as a reference card apart from the exception mentioned the better performing gaming card you can buy and simply stick in your rig would be a non reference Ti. For example grab a 980ti Lightning/ AMP extreme/ Hof/ Classified etc and any TX and which is the faster gaming card?
I've seen it breached on 1440p. That was with a TX running Advanced Warfare. The thing is a lot of these games won't ask for that much unless the card actually has it. But you know that already.
