*** The Official Destiny Thread (now includes 2.0 and TTK) ***
Is the black spindel worth the effort or is it all about that 310 rating for infusing? I tried a couple of times with lfg-ers last time but not successful, just wondering whether to try again tonight.
In the raid my 300 Defiance of Yasmin was doing 52k damage to Golgoroth but a 310 blank spindle was doing 74k IIRC. Part of the difference is the fact black spindle was 310 against 300 also it was different person so our light levels may have been slightly too. I still suspect though that even at 300 black spindle would hit harder.
More cool stuff on the dreadnaught...
Appears that if you use a Command Beacon Code and Wormsinger rune at the same time, the ultras duke it out and it it triggers something afterwards...don't think anyone's figured it out.
I have a Wormsinger Rune, Skyburner's Deployment Codes, and a Skyburner's Command Beacon. Be keen to investigate sometime....
Have you gotten the chest off the ship using the security codes from the Command Beacon fight?
That explains the damage difference we were seeing then. My 1000 Yard Stare (at 294) was hitting for just over 60k and I was getting 5 rounds in per reload with Triple Tap.
Interesting, my 1000 yard stare is 295 but I didn't use it as I thought a 300 Defiance would do more damage even though it gives away a little impact. I don't have triple tap on my 1000YS though ~10k extra a bullet isn't to be sniffed at.
I don't know what it is about TTK but really don't seem to ever be using glimmer, I think I have got down to 15k but hit the 25k cap again yesterday. That isn't included the 50k ish I have the vault. I assume you mean mouldering shards? If so AFAIK they only come from the raid but you can pick up 10-15 per raid so even with 1 character by the end of the second raid you should have the 20 shards for a double drop.
The new ghosts, I pull in so much glimmer without noticing just by killing things.
Can you share where you found this information? I have a Wormsinger rune and one of the Skyburner items and would be interested in trying this out. I just don't want to waste either of the items which I have already done twice before.
https://www.reddit.com/r/DestinyThe...ew_wormsinger_rune_command_beacon_secret_let/
Triggering both hive and Cabal at the same time triggers an 'Champions are about to clash'....what you're supposed to do after that is a bit of an unknown.
Possibly spawning another champion once one of them has killed the other?
I took a look at your setup and your sniper was around 10-20 levels higher than mine. It does obviously make a big difference.
Unfortunately it's a shotgun that is my highest special apart from telesto.
I'm looking for a perfect roll on a sniper before I upgrade one though. I'll probably get a perfect PVP roll and just use it for PVE anyway because I can't be bothered infusing 2 to a high level.
I need to complete both the Titan subclass quests the ones where you need to get 7 orb kills with Fist of Havoc and the 30 warded kills. Does anyone know which strikes are the best and is anyone willing to give me a leg up with it please?
thanks
